Weld Prostar 15x10 with 6.5" backspacing??
Old Apr 16, 2007 | 11:15 PM
97formulakid's Avatar
I bought these wheels off a friend of mine and he said he ordered them with the most backspacing he could get, which should be a 7.5". Well today when I was grinding down the calipers I had them mounted up and they look like they stick out a little too far. I measure the offset and they were a 6.5" to my knowledge.
He was running a 325/50/15 M/T Drag radial with no problem.
First off, do they make those in a 6.5" back spacing?? Then, since he was running a 325/50/15 with no rubbing issues, shouldn't I be able to run a 275/50/15 with no problems??
Old Apr 17, 2007 | 01:07 AM
CamaroRacing12's Avatar
i have no idea but i want some damn prostars also lol
Old Apr 18, 2007 | 06:43 PM
yeah i got a smoking deal on these (200 for the set) and now im trying to get some 15x3.5 for the front.
anyone have an answer to the orginal question?
Old Apr 19, 2007 | 12:04 AM
You need the 7.5" backspace to put the tire where this one is:
Yes, they make the 15x10" Pro-Stars in 7.5" BS, 6.5" BS, 5.5"BS, 4.5" BS etc.....
If they are sticking out 1" more than that, they aren't going to rub on anything inside the wheel well, but you run the risk of the fender lip coming down on the tread or sidewall of the tire.
Old Apr 19, 2007 | 12:15 AM
ahhh i want some sooo bad wish i got a deal like u but with the 7.5" backspacing
Old Apr 21, 2007 | 11:55 AM
Injuneer, that is what I was thinking. He didn't have any issues running a 325/50r15 M/T Drag radial on it and it never hit his fenders. He really didn't know the backspacing so when he ordered them he told them he wanted the wheels to sit in as far as they could go.
Hopefully I will get lucky and the 275/50 will work. Thanks!!
Old May 5, 2007 | 09:53 AM
Vicious95Z28's Avatar
Are you still using the factory 7.5 rear? If so when you upgrade to a 12 bolt make sure you order it 1" narrower per side.
Old May 5, 2007 | 10:06 AM
Yeah I'm still running the factory rear. BTW, I got the drag radials in (275/50R15) and mounted them on the wheels and got them on my car. They don't stick out any further than the ones in Injuneers pictures. I must have been measure the backspacing wrong or something. They don't rub and don't hit the fender lip.
BTW, they hook like a motha!!!! No spray launching at 3 grand with 30PSI and no burn out, they bogged the car down!! I can't wait to try it on the spray and get the gears in!
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
4586
Aug 22, 2015 01:09 AM
TGGodfrey
Aug 18, 2015 06:08 PM
4586
Aug 18, 2015 07:08 AM
