Torque arm weight - Mild Steel vs Chrome Moly
Old Apr 13, 2007 | 04:49 AM
j0n's Avatar
j0n
Like the title says, what is the weight savings from going with a chrome moly torque arm over mild steel?
Has anyone actually weighed each?
Old Apr 13, 2007 | 08:46 AM
ChevalierSS's Avatar
I've never measured, but the weight difference is negligible. Both are steel alloys. Chrome-moly contains only a very small amount chromium and molybdenum as part of the alloy make-up (less than 1% of each), the rest of the metallic make-up is pretty much the same.
Old Apr 13, 2007 | 09:13 AM
j0n's Avatar
j0n
errr...i appreciate the well-thought-out reply! you definitely know your stuff, however, i earned a "D" in high school chemistry LOL. What kind of weight difference constitutes negligible?
Old Apr 13, 2007 | 09:18 AM
hotpart's Avatar
Former Vendor
If they are using the same size diameter and wall thickness tubing they will weigh the same. The only difference is if the chrome-moly was not stress relieved and heat treated after welding you will have a very expensive part which weighs the same, has the same strength, but will have brittle weld areas compared to the mild steel.
Old Apr 13, 2007 | 09:25 AM
j0n's Avatar
j0n
haha thanks alot...saved me $125
Old Apr 13, 2007 | 11:03 PM
LT1 POWR's Avatar
I think it was only like 5-10lbs anyway.
canbaufo
May 5, 2015 03:43 PM
KYWes
Apr 24, 2015 09:17 AM
1963SS
Feb 6, 2015 10:05 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
