vibration
Old Mar 29, 2007 | 07:32 PM
leppnastyz28's Avatar
vibration
Hey guys i just bought a 96 z28 6 spd (my 5th camaro now) and i realized on the way home a lil but more so now that i have been driving around that if im juss sittin still idling n rev up the engine to anything above 3500 rpms i get a very noticeable vibration from underneath the car its worse when driving it if i take it above liek 3200 rpms ne thing above that i get a very bad vibration from wat feels like right underneath the shifter in the center of the car i was thinking it could be my driveshaft or possibly the torque arm maybe a rubber bushing worn or something i havent really got to get underneath the car and look yet and as far as i know it might not even have to do with either the driveshaft or the torque arm those r juss guesses so has ne one else ever experienced ne thing like this or have an opinion as to wat might be the problem and wat i should do to fix it becuz right now i can deal with juss driving it around and shifting at 3000 rpms but ide still like to kno wat it is cuz as far as i kno it could be an easy fix but i dont really wanna dump a bunch of money into this z liek i was plannin on in the next few weeks if its somethin thats goin to turn into more of a problem thanks in advance for any advice u's might have
Old Mar 29, 2007 | 08:34 PM
chevynutman's Avatar
if you can get it to happen just sitting there and reving it over 3500 it's not the driveshaft it could be an engine or clutch balance issue also try reving it with tranny in neutral and let out clutch and see if it changed at all
Old Mar 30, 2007 | 01:09 AM
yeh at first i didnt kno that it happened when u juss revved it while sitting still its really bad though when driving so i still think it could be a possibility that maybe its part of the problem but yeh it happening while sittin still really boggles my mind as to wat exactly it is ill try wat u said tho tomorrow n update this as to wat happens then thanks for ur imput
Old Mar 30, 2007 | 08:17 PM
im gettin like a noise of somethin hittin on somethin when idling now im beginning to think its somethin inside the clutch becuz when i push in the clutch the noise stops?? any similar situations or ideas of a possible problem/ fix
Old Apr 13, 2007 | 11:33 PM
blue's Avatar
I might have a similar situation with my '94. It's not bad enough to feel a vibration revving the engine, but on idle if I listen under the car I will sound like a clack....clack... every two seconds or so. It's not very loud at all, almost not noticeable but I have a very trained ear now to this vehicle and I think the noise is something wrong. Sounds like it's coming from around the area of the flywheel. I think it might be out of balance. The front seal leaks and always has, despite being replaced twice. The crankshaft goes through this seal, and if something was out of balance, it might wobble just a little and cause the unstoppable leak in the front.
They put weights on the flywheel in the factory when they balance it I think. Maybe one of them fell off on yours, or maybe your clutch is poorly balanced. I don't know if either of these is common but it's a thought. Also, as I remember they put little weights in the vibration damper for balancing, and they tell you to be sure you put the damper back on the same way if you take it off.
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
Apr 16, 2015 09:57 AM
