3.23 vs 3.73 gears,is it worth it?
Old Mar 27, 2007 | 11:49 PM
leanjay's Avatar
i'm going to swap out my 3.23 gears for a set of 3.73's, is it worth doing or should i go with the 4.10 ratio? also does anyone know the correct mph for 6th gear with the 3.23, 3.73 and the 4.10? and my last question is where is the best supplier for the ring gear,pinion,master install kit,shims and ring gear bolts?? any help would be welcomed.
Old Mar 28, 2007 | 12:32 AM
mrmint69's Avatar
Unless the cars been changed before the manuals came with 3:42's so the difference would just be very little. I would go with the 4:10's for sure.
Old Mar 28, 2007 | 09:12 AM
MEAN LT1's Avatar
If your going from 3.23's to3.73's you'll notice the difference. From someone who has 3.23's with there m6 right now and driving an m6 with 3.73's, you can totally feel the difference.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
blac94Z
29
Mar 25, 2015 04:21 PM
