Sat radio antenna question
Old Mar 27, 2007 | 11:48 PM
Justin Horne's Avatar
Is it true you can mount it (on a 97 TA WS6) UNDER the rear spolier? Such that it is on the trunk lid, but inderneath the wing part?
Also, since I have a fiberglass hood, can I mount it UNDER my hood? I've read both of these, but not heard, "yes, you can" things about them.
Thanks.
If not, what would you suggest, the t-top center bar?
Old Mar 28, 2007 | 09:44 AM
96 Z 28's Avatar
All the the one's that I have seen are magnetic mount, so mounting to Fiberglass may be tough
I have the small round one, and it sticks nicely to the roof right behind the T-tops, wires run down the water channel and then through the weather seal for the trunk deck lid into the car Pretty nondiscrete
I would also avoid hiding the antennae, as it works best if not blocked. It is feasible to be hidden, but you do lose some reception
Old Mar 28, 2007 | 12:09 PM
cjmatt's Avatar
i mounted mine on the inside of the passenger rear fender near where the antenna is and it works fine
Old Mar 28, 2007 | 02:21 PM
PentaVolvo's Avatar
you can mount it under the hood no problem since its fiberglass... vette guys do this alot even with there ipass
Old Apr 3, 2007 | 11:13 AM
NAVY01Z's Avatar
mine is on the dashboard. centered all the way at the front under the windshield. works fine.
Old Apr 7, 2007 | 11:06 PM
Awesome, it's mounted underneath the hood, working fine. Thanks, and for anyone else, it's a great place to put it.. Run the lead through the wirewall hole, mount it to the top of the wheel well, and no one can tell.
ChrisFrez
Mar 8, 2015 01:22 PM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
$hawn
Aug 3, 2002 04:59 AM
