Rear End Swap?
Old Mar 20, 2007 | 04:25 PM
Blazin_350's Avatar
Post Rear End Swap?
I had a question, I tried to search for a thread like this but I guess I might have not worded it right or something. But I have an 1984 Stock camaro, with the stock 10-bolt limited slip rear end. We got a totaled 1994 z28 that was hit in the front that I took the rear out of, I was wondering how much trouble it would be to put the z28 rear in my car? I have drum brakes and the z28 has disks, also do you think its worth messing with? The car is a daily driver so I don't have anything real monsterous in it, I just wanna upgrade some things and I felt this would be the most cheapest option, correct me if I am wrong
Old Mar 21, 2007 | 12:14 AM
The 4th Gen 10-bolt rear axle assembly is 3" wider than the one in your 3rd Gen. You can resolve that issue with wheels with a larger offset. You have to decide if you want to get into that.
Old Mar 21, 2007 | 06:41 PM
respectirocz's Avatar
it is absoluetly worth it because its an easy disc brake conversion, another limited slip
the downside is that you can't use the stock rims since the rear end is wider
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
