What block??
Old Mar 16, 2007 | 02:52 PM
lineybiker_11's Avatar
What block??
i was wondering what kind of lsx block should i use for my next motor build. i would like to go at least 427 ci NA 550-650 hp and a little bit of No2 but i would like to keep it aluminum. what kinds and brands of blocks are out the for my application.
Old Mar 16, 2007 | 03:51 PM
VK's Avatar
VK
U said it. The Lsx block. .
Old Mar 16, 2007 | 04:20 PM
sorry not what i ment. i want a ls style block
Old Mar 16, 2007 | 05:08 PM
VK's Avatar
VK
If your looking to go as big as a 427ci, you'll need either the C5R block ~3,000$ or the new LSX block ~2,000$ .. a Ls2 might get you close.
Old Mar 16, 2007 | 05:43 PM
JimboManJones's Avatar
Do they make the LSx block in aluminum or does it still only come in iron?
Old Mar 16, 2007 | 05:47 PM
VK's Avatar
VK
I was reading about it in my GM High tech mag. I'm about 99% sure it all aluminum. The C5R and LS2 are iron if memory serves me right.
Old Mar 16, 2007 | 06:02 PM
LiENUS's Avatar
LSx is Iron with double head bolt holes and 6 bolt mains i believe
Old Mar 16, 2007 | 06:07 PM
VK's Avatar
VK
If i had my GM high tech i would double check, but like i said i was 99% sure.. there is always that 1% lol
Old Mar 16, 2007 | 06:24 PM
ls2 is aluminum
Old Mar 16, 2007 | 08:14 PM
MachinistOne's Avatar
Wow - make up your minds...
The LS2 and C5R blocks are aluminum.
The new LSX block from GMPP is Iron and very very heavy.
Forget the extra 20 cubes and just build a LS2 based 408.
Search the forums over at ls1tech, there are plenty of example builds that will get you the power you want.
The other option is to take a cheap production block and have Darton sleeves installed, that will get you 427 cubes.
Old Mar 16, 2007 | 08:31 PM
VK's Avatar
VK
Bah! Put an LT1 in there
Old Mar 17, 2007 | 12:10 AM
LiENUS's Avatar
650hp get a LS2 block. LSx is built for > 1000 hp power levels I believe.
Old Mar 17, 2007 | 08:26 AM
Ya i thought that the lsx block was iron, the c5r block to much $$, so i might see how much a sleeved ls2 block would be or maybe just go to like a 402 or 408 something like that. i just would like to have that all aluminum block though. i always that that clear acrylic lsx block that they have for the shows would be pretty sweet if it was actually functional. imagine being able to see your internals while it was actually running
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
