Pinion Nut Torque
Old Mar 14, 2007 | 11:25 AM
jordankeck's Avatar
Question Pinion Nut Torque
I replaced my pinion seal last summer and didn't mark the pinion nut/bolt relationship correctly, so now the rear end is mis-torqued. I didn't drive the car much after that but now I need to get the problem resolved, so I am going to replace the crush sleeve and set the torque correctly. The problem is, no one seems to know what the torque spec is. Can anyone help me?
Jordan
Old Mar 14, 2007 | 07:41 PM
Capn Pete's Avatar
I believe the spec is 20 - 22 inch-pounds of "drag" (meaning, snug the nut up just a little at a time, and turn the pinion with the inch-pound gauge, and the turning resistance should be 20 - 22).
You can almost do it be "feel" ... basically, you don't want the pinion to be able to spin resistance free ... you want just a small amount of drag, but too much and it'll put too much load on the pinion bearings, leading to premature failure.
I know this was discussed awhile back, and I believe that 20 - 22 inch-pounds was confirmed .
Old Mar 16, 2007 | 12:42 PM
Sgt. Spuds's Avatar
If your reusing the old crush sleeve, just torque it to 150LB's
Old Mar 16, 2007 | 04:22 PM
SnakeOiler's Avatar
150 lbs ?!
Old Mar 17, 2007 | 08:47 AM
jay_lt4's Avatar
the crush sleve is not re-usable,, never try, it is a 1 time only deal
yes use a new crush sleve and keep tightning the pinion nut till you get 20-25 inch/pounds of turning resistance
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
tdigger9899
Sep 7, 2015 10:56 AM
