Turn Signals Blowing Fuses
Old Mar 14, 2007 | 02:33 AM
Don350k's Avatar
Well as it says, i got a short somewhere in it, wondering if ne1 has a wiring schmatic for the turnsignals foor 95 base maro, and if there is any problem aeras in these cars, i feaar its behind the stearing wheel in the multi switch, and i hate pulling the weel to do it but i gues i gotta do what i gotta do.
so basicly, any problem aeras and ne1 w/ a schmatic plz?
Don
Old Mar 14, 2007 | 05:45 AM
Guest47904's Avatar
Guest
Always start easy
Never start with the hardest section. Check the easy stuff first.
My first question is does it blow the fuse only when the blinker is turned or does it do it when it is off too?
Does it do it in both directions if it only does it when it is turned on?
The turn signals pass thru the large rectangular grommet near the master cylinder. Any time wires pass thru a body panel, that is where you start.
I would suspect the switch last. There's a way to test for it without removing the wheel.
Give us some more info and we will go from there.
Old Mar 14, 2007 | 12:19 PM
Z28SORR's Avatar
Check for corrosion in/on the turn signal light bulb and socket. esspecially the rear lights.
Old Mar 14, 2007 | 02:28 PM
Don350k's Avatar
UPDATE: well, the fuse blows when put in reverse, checked the reverse lights/wiring in the back, all looks good, no corrosion or bare wires, next guess is by the trenny, where is the switch on a 3.4 5sp? possible switch went out?
Don
Old Mar 16, 2007 | 02:15 PM
Don350k's Avatar
ne1?
Old Mar 18, 2007 | 02:51 PM
Don350k's Avatar
Plz?
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
