lt pc's and magnaflow
Old Mar 13, 2007 | 08:02 PM
custom95's Avatar
I bought lt coated pacesetters w/ y pipe and a magnaflow catback for my 95 and I plan on doing some kind of cat bypass- I know there are cat replacement pipes, but I have access to a full shop with tubing expanders and benders so would it be easy to make one instead? I'm sure it would be a lot cheaper. I also removed egr and air pump and will be having these deleted out of my computer so do I still to run O2 sensors and will the removal of egr and air affect the readings on my O2's?
Old Mar 14, 2007 | 03:14 PM
2000GTP's Avatar
When you mention a cat bypass, you are not thinking of reusing your stock y-pipe, correct.? The stock y-pipe will not even come close to bolting up to LT headers. I'm a little confused, are you going to add a cat into a Pacesetter off-road y-pipe, and then a bypass after that?
Old Mar 14, 2007 | 06:30 PM
turnin20s's Avatar
Yeah I'm confused too. You got the y-pipe for the LTs right? If so you do not need to do a cat bypass since all of that will be removed when you take off the old exhaust. The y-pipe that you got with the LTs should go right into the magnaflow catback and you don't need any cat bypass or anything.
Old Mar 14, 2007 | 11:19 PM
custom95's Avatar
Yep, I've got the off road ps y pipe and your saying that this eliminates the cat? This should bolt up to the magnaflow intermediate pipe? I looked at the end of the intermediate pipe on the magnaflow kit and it has a flange, where as the ps y pipe is a slip fit. Anyhow, as long as the two meet together, I can modify the intermediate pipe to fit the slip fit on the y pipe. This sound right?
thanks
Fatdog2
Sep 26, 2015 12:06 AM
JJOHNROE
Sep 8, 2015 05:39 PM
SSCAMARO1659
Aug 30, 2015 08:45 AM
Red97LT1
Feb 5, 2003 07:52 PM
