Need PE/dyno help ASAP!
Old Nov 21, 2002 | 11:22 PM
Dan K's Avatar
I'm going to be tuning a couple of cars on the dyno saturday and was just wondering how much of a change to the PE vs. RPM table is going to be required to change AFR on the wideband...say .25:1. Basically what kind of change would be required to go from 12.75:1 to 12.50: 1.
Anybody that's done this....I'd appreciate your experiences with this!
Old Nov 22, 2002 | 12:39 AM
cmillard's Avatar
Post
It varies from car to car, but a general rule of thumb is 10 percent PEvsRPM will richen the car about 1 AFR point (ie 13:1 to 12:1).
Quick way to tell what you need- do two baseline runs - the second will be higher and slightly leaner due to the carbon and junk blowing out. Shoot for 12.5-13:1 on a warmed up engine- the more heat soaked the engine gets the leaner it runs, so stay consistant with you changes.
Hope this helps, if you're near Virginia I tune at Woodbridge Dynotech.
-Christian
www.carprogrammer.com
Old Nov 23, 2002 | 03:13 PM
Dan K's Avatar
Thanks Christian, worked almost perfect!
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
