Anyone ever delete their TCS box??
Old Feb 20, 2007 | 01:12 PM
nb 96 z's Avatar
Has anyone successfully deleted their traction control box over the drivers side valve cover?? It is starting to annoy me. I did a search and it didn't look like anyone has had success, with an obdII car. I want the box gone, while maintaining my abs and cruise.
Old Feb 20, 2007 | 02:53 PM
ZL1modified's Avatar
i deleted it... all you need is the throttle cable from a non-tcs car... (not sure of the part#) the asr light will stay on but it's on if you have it turned off anyway...
not sure how it acts with the abs, i removed my abs also (i know the abs light wil come on, but i dont think it effects braking)...
Old Feb 20, 2007 | 03:39 PM
nb 96 z's Avatar
Yeah, I've heard that if you delete the traction control box, then your abs goes too, which I don't want, but I may have to. Anyone else?
Old Mar 8, 2007 | 06:37 AM
97BLOWNTA's Avatar
I removed the TCS box, it did take out the ABS and also the cruise ctrl. I am going to remove the ABS.
ZL1modified,when you removed TCS and ABS, the two brake lines that go to the rear wheels, did you just use a junction block up in the engine bay to tie the two lines to the rear from the single line from the master?
Aaront810
Aug 29, 2020 09:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Sep 11, 2015 09:44 AM
zk06
Sep 9, 2015 11:39 AM
tnmotown
Aug 10, 2015 11:52 PM
