Header bolts...
Old Feb 18, 2007 | 07:02 PM
ArcticFuryLT1's Avatar
Header bolts...
yeah so the guy that put the headers on my car a little over a year ago didnt tighten them down properly i guess, because two of them finally rattled out on my way home the other night. what size are the bolts and where can i get them? and do i change the gasket too?
Old Feb 18, 2007 | 07:06 PM
2000GTP's Avatar
I would get a set of 1" ARPs or Stage lockers. I would also replace the gaskets for good measure. I have seen gaskets get burned up or blown out due to header bolts backing out too much.
Old Feb 18, 2007 | 07:26 PM
so can i get those from summt? are they just called 1" header bolts or is there a specific size or part number for them?
Old Feb 18, 2007 | 07:46 PM
OBE1 95Z28's Avatar
Header bolts need to be retightened after several thermal cycles as the header gasket may compress. Your mechanic should have suggested that they be checked. If you have any ticking sound by the exhaust manifold were the bolts backed out, then I would replace the gasket(s). If you don't replace the gaskets, check that the rest of the bolts are tight. Remember, the bolts only get tightened to about 20 ft-lbs, they thread into aluminum heads.
Old Feb 18, 2007 | 09:18 PM
the header bolts fell completely out...i noticed when my car started sounding like a tractor, lol
Old Feb 19, 2007 | 10:42 AM
2000GTP's Avatar
Yeah, you can get them from Summit and should be listed as 1" bolts.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
