LT1 TB on 3.4, can it be done?
Old Nov 21, 2002 | 07:55 PM
soontobeGN's Avatar
Will a throttle body from an LT1 fit on a 3.4 V6.?
Also will LS1 injectors fit in the 3.4?
Thanks in advance.
Old Nov 21, 2002 | 09:21 PM
zlightning's Avatar
LT1 throttle body can be made to fit yes. You have to fab somethings up though. Taigo has one. Find his site and you will see. A company that no longer works with our engine, Nu-Teck, did the work.
Old Nov 21, 2002 | 09:49 PM
bigsteve7's Avatar
The LT1 TB ought to outflow the 3.4 one, but by how much and would it even be a worthwhile mod? Something tells me it woudlnt be worth the swap.
Old Nov 22, 2002 | 01:29 AM
oil pan 4's Avatar
It won't be of much help unless you have some real mods like a big cam some headers or a power adder.
Old Nov 22, 2002 | 09:52 AM
soontobeGN's Avatar
OK, what i am doing is getting a 3.4 motor to work on, im going to put a nice sized cam in it, some high flow heads, headers, 2.5" exhaust, etc. will the Lt1 TB help with that??
Old Nov 22, 2002 | 10:58 AM
ibanez6rg's Avatar
It will be better than the 3.4 TB
Old Nov 22, 2002 | 02:51 PM
MustangEater82's Avatar
what he said and Tiago did do it. Personally I would look into getting that other stuff taken care of before you do the TB, better to do the big things then work tyhe little stuff around it.
you do everyhting you said but still have a 3.4L TB, your car will be much faster. YOu put on a lt1 TB and don't do the other stuff, you will barely notice a difference, but a dent in your wallet.
just my thoughts...
Old Nov 28, 2002 | 01:54 AM
Ace_437's Avatar
If you're going to do all that, why not just get an actual LT1? Why spend all the extra money on the 3.4 when you could find a complete LT1 for $500 to $1000?
Old Nov 28, 2002 | 01:31 PM
ibanez6rg's Avatar
Ace_437 does have a good point. To each his own - do whatever floats your boat!
Old Nov 28, 2002 | 10:39 PM
TheV6Bird's Avatar
Because a trans, driveshaft, rearend, PCM, wireing harness, and cooling system also cost money as well.
Old Nov 28, 2002 | 10:46 PM
nova's Avatar
Some people just do not understand the potential that the 3.4L has. It just needs a little coaxing to become a mean machine.
Old Nov 28, 2002 | 11:18 PM
Ace_437's Avatar
What? Peppy maybe, but not mean.
Old Nov 30, 2002 | 05:17 PM
Tiago's Avatar
Originally posted by camaroRI
the 3.4 is a joke, you could spend massive ammounts of money on a complete 3.4 rebuild, all performance parts, blah blah blah and still you wont be close to a stock LT1 or LS1
Ryan
I beg to differ
work it , it will put out hp
my plans will take it into the 500 hp range, I hvaen't spent as much as a lt1 swap on teh engine yet.... will be a little more after my new motor, but then again I will have a unique 500 hp 3.4, not a STOCK lt1.
Id like to think my car is pretty unique already even at 300 ish hp that its at right now. Its worth it to me, but to each their own
BTW I have the LT1 thorttle body, check my site for pics.
SpeedJunkee
Jan 27, 2015 10:02 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
TheV6Bird
Aug 27, 2002 10:38 PM
Eric H
Aug 10, 2002 06:39 AM
TheV6Bird
10
Aug 2, 2002 08:00 PM
