Magnaflow Install?
Old Feb 16, 2007 | 08:30 PM
ls1king's Avatar
Magnaflow Install?
I need to find out how long and simple it would take to install a magnaflow exhaust system in my 00 z28. any certain tools that i need?
Old Feb 16, 2007 | 08:46 PM
fasteddie94's Avatar
It's a piece of cake once you get the old exhaust off. You'll need to cut the stock pipe where it goes over the axle. No real specialty tools though. I'd say 2 hours tops, if you have little mechanical ability.
Old Feb 17, 2007 | 09:12 AM
2000GTP's Avatar
An electric reciprocating saw made short work of chopping off the old exhaust. Other then that, installing it is quick and painless.
Old Feb 22, 2008 | 05:12 AM
blkgagt94's Avatar
what you mean quick an painless iam doing mine an the pipe off the cat is welded so you gota cut it. so iam cutting the pipe b4 the cat using a adapter to the new cat i bought then welding the new pipe from the kit to the new cat then clampin the rest of its way. also i got the 3" pipe from the cat back
Old Feb 22, 2008 | 08:20 AM
2000GTP's Avatar
Are you connecting the i-pipe portion of the catback directly to the cat, or is there a run of pipe after the cat as well. If so, what is the diameter of the cat or the run of pipe? If it is 3 inches, the i-pipe portion of the Magnaflow catback is slightly oversize of 3 inches so it will slip right over it. Then you can use your choice of a band or u clamp.
Old Feb 22, 2008 | 09:30 AM
blkgagt94's Avatar
iam cutting it right b4 the cat off the y-pipe then using a 3"swell pipe adapter then to the new cat then the magnaflow 3" catback pipes an i just bought a cut out an gonna install it right b5 the pipes bend over the rear end. also can u pass emmissions with a cut out? if its covered with the cap?
Old Feb 22, 2008 | 10:41 AM
2000GTP's Avatar
Keep it capped, any type of exhaust leak could disqualify you, that is assuming they even look under there.
Old Feb 22, 2008 | 10:51 AM
blkgagt94's Avatar
cause i wanna put it on when i do the pipe so it can be welded on good since it will be off car. if i did it after emissions be hard since u gota cut the pipe then try the best to weld the top side.
Old Feb 22, 2008 | 11:09 AM
2000GTP's Avatar
I have a cutout on my car, I just capped it up before taking it in. With the car being noticably louder, I didn't want to attract any attention to the underchassis. I don't see an issue with installing it now, just cap it off when taking it in.
Old Feb 22, 2008 | 11:12 AM
blkgagt94's Avatar
k kool once u cap it off you dnt really here it do you like leaking threw the cap?
Old Feb 22, 2008 | 11:16 AM
2000GTP's Avatar
You shouldn't, there should be a gasket there anyway. My QTP cutout had a gasket, it is basically a 3-bolt collector gasket so they are pretty easy to find and buy if you don't have one.
Old Feb 22, 2008 | 11:42 AM
blkgagt94's Avatar
ya i just bought mine 3" one off ebay $56
Old Feb 22, 2008 | 03:16 PM
Kaj's Avatar
Kaj
All you need is an impact wrench with a chisel bit. And go to town right before where it bends up over the axle. With an impact it took me about 5 minutes to knock the stock exhaust right off. Easiest way to do it imo. Then the install is cake...
Old Feb 22, 2008 | 10:38 PM
johnnyb's Avatar
When i did my magnaflow, the hangers didnt line up correctly so i had to make new ones. I know someone else that had the same problem, but it sounds like most ppl dont. Just throwing it out there even though its wasnt really a big deal to make it fit
Nov 18, 2023 07:21 PM
drptop70ss
May 4, 2015 08:22 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
thenewkid
Nov 27, 2014 09:41 AM
Evilfrog
Aug 7, 2002 11:36 PM
