325's mounted w/ Jegs version of the Prostars
Old Feb 12, 2007 | 11:12 AM
cwaldt's Avatar
Got my 325's on this weekend. It wasn't that hard to get them to fit. The rear wheels are 15x10 w/ 4.5 backspacing. I had my Moser 9" narrowed 3" per side. The fronts are 15x4 w/ 1.75 backspacing. These are the Jegs wheels not the Welds. Click on the pictures for a better view of these. I don't think you could tell much difference between the Welds and Jegs version. Plus it was a whole lot cheaper.
I have some more pic's of what I had to do to get them to fit. As stated the rear was narrowed 3" per side. Also had to have the adj. LCA's and panhard bar, adj. torque arm as well.
Old Feb 12, 2007 | 11:56 AM
From the description in the catalog, they are one piece cast wheels, so they are not the same as the Pro-Stars. The Pro-Stars are made of two cold forged sections that are welded together. The Pro-Stars weigh a bit less. The JEG's wheels appear to be the old Weld "XP" series wheels, that Weld discontinued a year or two ago. Summit is selling the same wheels under the Summit name.
Old Feb 12, 2007 | 12:05 PM
cwaldt's Avatar
I agree there is some difference. But I didn't want to deal with the wait on the welds and plus the price is pretty attractive in itself. But over all not many people are going to realize that they aren't Prostars without looking at them up close.
Old Feb 13, 2007 | 08:03 AM
teke184's Avatar
wow...looks like you could rock crawl in that thing...
why the 4x4 look??
if it were a bit lower it'd look good
Old Feb 13, 2007 | 11:44 AM
cwaldt's Avatar
It looks alot higher than it actually is. Especially without the front nose. Keep in mind the front tire is a 26" stock height tire and the rear is 28" tall. I may take the rubber spring piece out and put some heater hose on my coil to get an inch drop in the rear. But I've still got to put my 3" true dual x-pipe setup on as well.
Old Feb 13, 2007 | 12:30 PM
Jlo's Avatar
Jlo
I think the wheels look good, how do they feel do they feel light when you were bolting them on??
Old Feb 13, 2007 | 12:48 PM
cwaldt's Avatar
The rears were heavier than the stock wheels & tires together. Theres alot of rubber in those tires. Of course the fronts were alot less in weight. So I think that it probably even's out and you get alot more rear tire without any extra weight.
Old Feb 13, 2007 | 08:40 PM
Jlo's Avatar
Jlo
what mods did you have to do to get the 325 tire to fit??
Old Feb 14, 2007 | 06:58 AM
cwaldt's Avatar
Adj. panhard bar, adj, LCA's, adj. torque arm. Beat and bang in the fender wheel, cut out bump stops and grind the calipers.
Old Feb 14, 2007 | 12:04 PM
Jlo's Avatar
Jlo
You use any wheel spacers??
Old Feb 14, 2007 | 01:10 PM
cwaldt's Avatar
Yeah, I used some spacers on the front. I can't remember the size but it was the smallest on JEG's has listed in there catalog. I still ground down the brakes some but I used the spacers to make sure there was enough clearance on there.
Old Feb 14, 2007 | 01:16 PM
Chevy16's Avatar
i actually like those, theyre pretty sweet looking
Old Feb 16, 2007 | 08:21 AM
Jlo's Avatar
Jlo
I see you have the front bumper off do you plan on removing the bumper support??
Old Feb 16, 2007 | 09:38 AM
cwaldt's Avatar
Yes, I'm going to leave the bumper support off. I actually took the bumper off to make it easier to work on the BBC conversion.
Injuneer
Apr 25, 2022 06:22 PM
97blackformula
Aug 27, 2015 06:02 PM
Aug 5, 2015 08:35 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
