what head gasket for my lt1 383 with nitrous
Old Feb 12, 2007 | 09:22 AM
cgworth's Avatar
whats a good head gasket to use on my LT1 383 stroker , i plan on shooting 150 shot of nitrous, heads and block are NOT decked
several suggestions and part numbers would be apreciated
Old Feb 12, 2007 | 09:57 AM
VK's Avatar
VK
Fel-pro's 1074
Jegs : 375-1074
So far they hold ~8 psi boost with stock shortblock well. Arp head bolts also.
Old Feb 14, 2007 | 02:53 PM
cgworth's Avatar
ttt.. i need it for 30 over std bore
Old Feb 14, 2007 | 03:50 PM
Ray@NitroDaves's Avatar
the 1074's will support a 4.125 bore
they are currently in my 396
But I prefer the Cometic multi layer gasket much better.
Old Feb 15, 2007 | 12:55 AM
TurboSS's Avatar
Ray,
Do you have any special application procedures with the cometics for elivated HP per cube applications?
-Nelson Raceing Engines uses some kind of sealent on the head gasket and deck.....
-Some say the head should be retorqued after a heat cycle or two...
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
