Broken Transmission mount?
Old Nov 21, 2002 | 01:06 PM
abarus's Avatar
Question Broken Transmission mount?
How can you tell if you have a broken transmission mount? When I shift from park to drive or reverse I feel a loud clunk and it feels loose?
Old Nov 21, 2002 | 04:14 PM
NEWBIE T/A's Avatar
Lightbulb I'd look at the rear end first !
More than likely it's slop in the driveline.
As far as a broken mount, I *believe* you have to get under the car & try to pry on the mount. Chilton's & Haynes's probably will do a better job of explaining it, but you are looking for tears or obvious signs of the rubber being shot.
Here is a good pic http://csce.uark.edu/~jgbertr/rb/trans_mount.jpg
Compliments of Shoeboxes' site http://home.swbell.net/shoebox/index.html
Good Luck !
Britt
Old Nov 21, 2002 | 05:39 PM
mehoffz24's Avatar
Get under the car and pry on the trans with the pry bar on the crossmember, you will see how the mount is moving. if it is real bad you will notice the rubber seperating from the mount itself.
Old Nov 21, 2002 | 06:39 PM
jd13's Avatar
If you have a broken mount, I suspect you would feel the whole thing banging against something.
I broke a tranny mount about a month ago in my thirdgen. Anytime I accelerated and gave the car some torque (nearly all the time in a TPI) I could actually feel the whole tranny *BANG* or *CLUNK* against something. Didn't sound or feel pretty, but got it fixed for cheap and no other problems from it.
Old Nov 22, 2002 | 12:34 PM
abarus's Avatar
Thanks for the feedback. The rubber was showing some cracks and wear so I replaced it, but it looks like it is just slop in the driveline.
PublicEnemy1
Apr 7, 2015 12:21 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Sep 2, 2002 10:42 AM
