Loud metallic rattle!?!?
Old Feb 8, 2007 | 09:36 AM
psychocabbage's Avatar
Ok. this just started up.. not sure where the sound is coming from.. Put the car up and shook everything and its all tight.. no wobbles..
Turn the car on.. nothing.. about 30 seconds later a rattle starts.
most noticeable when the car is idleing. I am sure its there at highway speeds but its drowned out by other sounds I am thinking..
sound changes as engine RPMs increase it increases.. Cluth in or out makes no difference. Rolling makes no difference..
any ideas of where to start looking!??! Almost hitting 90K miles. I have NOT done the following:
any mods (the exhaust is stock..)
changed plugs
replaced the serpintine belt
replaced any pulleys
so could this be some sign that I need to do some maintenance or could it be the tranny? I just had the clutch replaced 4K miles ago.
Old Feb 8, 2007 | 11:14 AM
KPI's Avatar
KPI
Catalytic converter rattle? It can be pretty loud.
Old Feb 8, 2007 | 12:38 PM
Bayer-Z28's Avatar
.. YEp. They'd mostly rattle at idle..
Old Feb 8, 2007 | 12:56 PM
so, ya think its finally gone south? hmmm lets hope! hehe
I think I still have that recall paper..
Old Feb 8, 2007 | 01:05 PM
2001NBMZ28's Avatar
If it's coming apart inside try beating on it with a rubber mallet with the engine off - don't leave any marks though, they may not honor the warranty. Also make sure the 02's are in tight, friend of mine had one of his rattle - believe it was the metal ring between the sensor and the cat.
Edit: Should be throwing a code if it's the cat, right?
Old Feb 10, 2007 | 09:45 PM
Capn Pete's Avatar
Not necessarily. Mine would periodically throw the codes for Catalyst Efficiency Below Threshold (P0420/0430 ... think I was getting 0420) but when one of mine actually failed (sounded like a can of marbles being shaken around under there! ) there was no code being set .
Likely, that's the problem.
Old Feb 15, 2007 | 11:40 PM
BLKLT1's Avatar
Sounds like a cat to me, exact same sounds, try the mallet idea, you should be able to even bash it with your fist hard enough to make it rattle.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
