Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
What Ohm injectors to use ???
Old Feb 3, 2007 | 11:24 AM
AZ2ENVY's Avatar
What impedence injectors do i need for a 94 LT1 F-car ? Thanks
Old Feb 3, 2007 | 12:18 PM
hotrod18_69's Avatar
High impedence
Old Feb 3, 2007 | 12:41 PM
AZ2ENVY's Avatar
Originally Posted by hotrod18_69
High impedence
Soooo...... What range of Ohm's do i need to look for ?
Will 3-8 Ohm work ? Thanks
Old Feb 3, 2007 | 02:31 PM
Stock injectors are around 12 ohms.
Old Feb 4, 2007 | 06:19 AM
rskrause's Avatar
Moderator
For practical purposes nearly any injector you buy will work unless it is noted to be a low impedance injector. Actually, even these will work for a very short period of time. But they flow so much more current than high-z injectors that the drivers will overheat and burn out quickly if you were to use low-z injectors. Low-z injectors work best with a "peak and hold" style of driver that works as follows (I started to write an "essay" and then found this that I could cut and paste):
Low- 1.7 to 3.0 ohms (Peak and Hold Driver/Injectors)
These type of injectors and drivers may also be called current sensing or current limiting. They are more expensive and complex than saturated circuit drivers, and are not generally used with domestic production ECUs. They are primarily used in aftermarket high performance systems. Most high flow injectors are low resistance (2-5 ohms) and use a peak and hold driver to activate them. The Peak current is the amount required to quickly jolt the injector open, and then the lower Hold current rating is used to keep it open for as long as the ECU commands. These require the extra kick from the higher current to keep the opening and closing time of the injector stable at the higher fuel flow rate. With this type of driver, 12 volts is still delivered to the injector, but due to the its low resistance, the current in the driver circuit is high. How high? Using Ohms’s Law we can calculate the current rating (12v/2 ohms = 6 amps). This is substantial current flow and a Saturated Injector cannot handle it. The drivers also come in two values; 4 amp peak/1 amp hold, and 2 amp peak/0.5 amp hold. Even though 6 amps may be available to operate the injector, the maximum it is allowed to reach is 2 or 4 amps, depending on the driver’s current limit.
High- 10 to 16 ohms (Saturated Circuit Drivers/Injectors)
Most domestic OE production EFI systems use an ECU with 12 volt Saturated Circuit drivers. These are very inexpensive, simple, and reliable. This type of driver works by supplying 12 volts to the injectors and the ECU turns it on and off to establish a fuel injector pulse. In general, if an injector has a high resistance specification (12-16 ohms) the ECU uses a 12 volt saturated circuit driver to control it. This means that the current flow in the driver and injector circuit stays low keeping the components nice and cool for long life. Conversely, a downfall of a Saturated Circuit driver is that it has a slower response time (and closing time) than a peak and hold type. This slower time can somewhat decrease the usable operating range of the injector energized by this driver. An injector operating on a saturated circuit driver typically has a reaction time of 2 milliseconds while a peak and hold driver typically responds in 1.5 ms.
Just to add a little: from the above you can understand why most very large injectors are low-z, designed to work best with a peak and hold type of driver. BTW: "z" is engineering shorthand for electrical resistance.
Rich
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
9
Sep 20, 2015 11:23 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
