What size gears are these?
Old Jan 24, 2007 | 02:10 PM
mrmint69's Avatar
I found a set of gears for the lt1 camaro. How do i know the ratio just from looking at them?
Old Jan 24, 2007 | 02:19 PM
OBE1 95Z28's Avatar
The rearend gear ratio refers to the relationship between the ring gear and the pinion gear. By dividing the ring gear tooth count by the pinion gear tooth count, the ratio is determined. For example, divide a ring gear with 41 teeth by a pinion gear with 10 teeth, gear ratio is 4.10:1 (41/10 = 4.10).
Old Jan 24, 2007 | 02:40 PM
Capn Pete's Avatar
2.73's - 41 / 15
3.23's - 42 / 13
3.42's - 41 / 12
3.73's - 41 / 11
3.90's - 43 / 11
4.10's - 41 / 10 (as stated)
4.11's - 39 / 9
Those are the common ones .
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Mar 22, 2015 09:12 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
