remote starter for manuel transmissions
Old Nov 20, 2002 | 01:50 PM
whitley54's Avatar
A while back i read on the internet somewhere that there was one or two companies that made remote car starters that would work for manuel transmission vehicles. Does anyone know where i can find out more about this?
Old Nov 20, 2002 | 03:58 PM
LT1Thunder's Avatar
I beleive that they all will work but you have to disconnect the nuetral safety switch in order fo it to work. I'm not sure if its called that but its the switch that get activated when the clutch is pressed. After you disconnect it you will be able to crank the motor without pressing down on the clutch. If you do it just make sur that you don't leave your car in gear when you try to remotely start your car!!
-Rick
Old Nov 20, 2002 | 04:24 PM
ibanez6rg's Avatar
Try posting this in the lounge also, you probably get a lot more replys
You could also do a search on it
Old Nov 20, 2002 | 04:34 PM
DrMilhouse's Avatar
The company is Clifford. The alarm is the avantgaurd. I'm not a big fan of clifford, but if you have a manual transmission and you want a remote start, that's about the only way to do it safely. I have a manual and I used a DEI alarm. It can be done, but yes, it can start in gear - and has... It's never inexpensive when that happens and it WILL happen to you... Maybe even after someone like a mechanic or someone else drives your car. (you always think that you'll be smart enough not to do that, but everyone has their stupid moments).
Yes, you're in the right forum for this and might be able to search for previous posts on this, you can also ask around at LS1.com, I'm not the only one that has done it. I'm also not the only one that advises against it...
HTH
Old Nov 20, 2002 | 04:43 PM
ibanez6rg's Avatar
Custom Car Audio and remote starters for manuels...hmmmmm
To me the lounge seems more, well, more suited
Oh well i know absolutely nothing
Old Nov 20, 2002 | 09:25 PM
NineSevenWS6's Avatar
Agreed.
Im on my second Clifford, both have been absolutly great.
Old Nov 21, 2002 | 02:46 PM
ibanez6rg's Avatar
Originally posted by NineSevenWS6
Agreed.
Shut up noob
Old Nov 22, 2002 | 10:42 PM
rage366's Avatar
Re: remote starter for manuel transmissions
welllll, just be careful with the remote starters...a thief can start your car as easily as you can. that's why i'd rather do it manually...although remote starters are cool
shokor
Old Nov 23, 2002 | 01:05 AM
DrMilhouse's Avatar
any remote start that is worth a crap has a starter kill function in it that is just (or more) effective than the VATS chip in the key thing... just a thought...
mdenz3
May 22, 2015 09:25 AM
warmeck
Mar 24, 2015 10:52 PM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
Michael Ozorowsky
Jun 16, 2002 09:05 PM
