17x11" Wheels on the Rear of my Camaro?
Old Nov 20, 2002 | 01:42 PM
SSnyper's Avatar
There's seems to be a bunch of conflicting information regarding what changes are necessary to fit a 17x11" wheel on the back of an F-body. Are bumpstop modifications required? Is is necessary to roll the fender lip? What about cars with aftermarket springs like a Pro kit or Sportlines?
Thanks very much.
Old Nov 20, 2002 | 02:57 PM
CobraKilla's Avatar
If you do a search this topic has been brought up every other week so there is good info on it...
Friend has 17x11s with nittos and sportlines...Doesnt rub unless there are a lot of people in the car or huge potholes...
Old Nov 22, 2002 | 01:47 PM
Njgunslinger's Avatar
i have 17x11's
I lowered the car a little with the slp level 1 suspension kit and the car doesnt hit the fender, but on hard turns, the inside of the wheel rubs against the inside wheel well.
Not sure what I am going to do, maybe cut it.
Old Nov 22, 2002 | 11:49 PM
LS1CAMARO's Avatar
Get the 50mm offset and make sure to get a adjustable panhard rod. Center your rear end and you should be good. Yes some cars need the bumpstop cut. You should not need to roll the fender lip with the 50mm offset. If you are lowering your car make sure to get the control arm relo brackets unless you don't need traction
Old Nov 23, 2002 | 11:03 AM
2001z28Shark's Avatar
Re: i have 17x11's
I have the same problem with my 18 X 9.5s (1/4 in. spacing). I can't believe you guys are talking about putting 11s on. I was almost gonna do that, but the dimensions were looking impossible. I guess they're not though if you use spacers, but I had everyone swearing to me that putting spacers on my car if I plan on racing it (and making it into a rocket ship) would be a really bad idea.
As for my wheels, I had to shave off part of the lower inside wall of the fender to get them to fit. There's about 1/2 in. clearance between the inside of the fender (at the bottom) and the wheels. And yes, through hard turning my tires rub pretty bad, but normal-daily driving is fine. Drag racing 60ft times have greatly improved, but I may never have the opportunity to autocross if I can't fix this problem...
Les
Old Nov 23, 2002 | 12:18 PM
LS1CAMARO's Avatar
Re: Re: i have 17x11's
Les
It is all in the offset. 17x11s with a 315 tire and a 50mm offset will fit without rubbing as long as my previous comments are done.
Old Nov 25, 2002 | 01:15 AM
acarnut's Avatar
Re: i have 17x11's
Will the tire fit up inside the wheel well if the car bottoms out? Or will it hit the fender lip? Or do you just hope you don't bottom out?
Old Nov 25, 2002 | 12:17 PM
sleeperZragtop's Avatar
why?
..why would using 17x11 rims and a 315 tire cause the rear end to move out of place? Hence the use a an adj. panhard bar. Is it fairly simple to adjust it? I'd also like to switch to 315 but I don't want to deal with all the problems.
Old Nov 26, 2002 | 01:47 AM
CobraKilla's Avatar
Heres how 315s look with sportlines on the back...
http://home.attbi.com/~brads454/wsb/index.html
Old Nov 26, 2002 | 09:50 AM
PAGregSS's Avatar
I've never had any problems with my 17x11s. They haven't rubbed once and the car has been drag raced and autocrossed. I don't have an adjustable panhard rod but I'm going to get one this winter as I've noticed that the drivers side tire sticks out about 1/2" farther than the passenger side. It wasn't noticeable until I put the big wheels and tires on. There's a link to pics in my sig. The pictures on the right hand side of the page are with the 17x11s on the back.
rockync7
Jan 1, 2015 05:10 AM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
ChrisFrez
Nov 30, 2014 08:41 AM
squarehead
Nov 21, 2014 08:02 PM
