rear end girdle
Old Jan 21, 2007 | 09:46 PM
pj97ragtop's Avatar
rear end girdle
which is good 97 ss camaro, thanks
Old Jan 22, 2007 | 07:34 AM
teke184's Avatar
may want to elaborate a little more...
i think you're asking which rear end girdle is best...and since all the rears in the fbodies are the same, year makes minimal differenance.
but any of the girdles that have the bolts to put preload on the internal parts...can't think right now what they are called.
Old Jan 22, 2007 | 08:55 PM
94_PatriotRed_Z's Avatar
I have a summit rear end girdle and have had no problems with it
Old Jan 23, 2007 | 02:50 PM
2000GTP's Avatar
They all do the same function, find whichever one looks the best to you and is the best price.
Old Jan 23, 2007 | 09:36 PM
godspeed1976's Avatar
They are normally refered to as T/A Girdles. They all work the same. They pretty much all look the same excluding the one you can get with the triangulated braces that mount to the tubes. So find the cheapest one, and you should be fine. I think Summit has the cheapest at $145
Old Feb 12, 2007 | 05:02 PM
Redbird1993's Avatar
The T/A is a specific brand of diff. girdle. I have one on mine. Mac and Summit both make them also. Some out there are just a heavy cover and don;t have the support adjusters that screw in to your carrier brg caps ...make sure you get one with the adjusters!
Old Feb 13, 2007 | 06:05 AM
As he said make sure to get a girdle not just an aluminum cover. T/A is a brand, but the others are based on there design. Thus why many people "refer" to them as TA covers. They are all basically the exact same thing with a different name on the back.
There is also a girdle with even more bracing from LPWRacing. You can read about it, and others being made in the "BULLET PROOF 10 BOLT? You be the judge! " thread.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
