flywheel balancing
Old Jan 11, 2007 | 12:30 PM
94_camm's Avatar
flywheel balancing
Ok when i had my motor built n balanced i was auto.which means they balanced the auto flywheel.i since then convert 2 manual an got a brand new stock flywheel.do i need to get this balanced like the other flywheel or am i ok?
Old Jan 11, 2007 | 01:16 PM
always faster's Avatar
If your engine was neutral or "0" balance you will need a neutral balance flywheel.
Old Jan 11, 2007 | 01:27 PM
97 6SPEED Z's Avatar
Question
Okay, this can get a bit tricky but try and stay with me here. When you engine was stock, it was balanced externally at the rear, (i.e. at the flywheel (manual trans), or flexplate (auto trans)).
When you then had your engine "built n balanced", did the engine shop rebalance your now(??) internally balanced motor with a "zero" (i.e. neutrally) balanced flexplate, or did they still use the factory "external" balance criteria???
If you can't get a hold of the shop that did your engine re-build to ask them these questions; then the only thing you can do now, is take your old flexplate from the auto trans setup, (which presumably ran well with your auto trans?), and have your new flywheel for your manual trans setup.......match balanced to it. Hope this info helps?
Old Jan 11, 2007 | 02:03 PM
94_camm's Avatar
the crank was internal balanced.i bought u brand new flexplate for my auto and they had to take some weight off the flexplate.and i know the flywheel weights alot more then the flexplate..
Old Jan 11, 2007 | 02:56 PM
94_camm's Avatar
ok just got bak form the motor shop.it was externaly balanced flexplate.so i gave him my flywheel and hes goin to balance it thanks alot guys
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
