Building a 10b to handle ~500hp.
Old Jan 10, 2007 | 02:58 PM
Bayer-Z28's Avatar
ok, I noticed that a couple people have thrown gears in their stock 10b's. Gear sets alone are not that expensive. I haven't gone to the track yet, but I am planning to start. I need stickier tires to keep me straight when I power shift. -Also doing that too much on a 10b =
How would I go about building a 10b on a budget to handle 500 ~ish hp. I don't think I will be breaking the 500hp/550tq barrier any time soon. I am getting a nitrous kit soon, that's how I came to those #'s. (My approximate fwhp/tq thus far is 386/397 + 150 shot of nitrous (max) = 536/547) -Might be slightly more since 160 stat install.
I was looking at a Strange 12b w/ 3.73's. From what I've read they are a direct bolt in replacement for about $2200.
Gears= $230
Axles= $250
TA Girdle= $150
Fluid= $20
______________
$550
??? Help me out here. Would this be worth doing even if I stay in the hp/tq #'s above?
Old Jan 10, 2007 | 03:27 PM
Kredz28's Avatar
Gears= $230
Axles= $250
TA Girdle= $150
Fluid= $20
______________
$550
The girdle itself adds some strength of course, and i know of guys running that girdle, aftermarket gears, unsure about the axles, but they are running 600 + to the ground. Its really a crapshoot talking about 10 bolts as i broke mine when i romped the gas hard in 1st gear...but then again i had a complete stcker, at 5600 ft altitude (350 whp UNCORRECTED) and street tires...now ive got the moser 9 inch with 31 spline axles, 4.11 gear and detroit true trac, and i LOVE it..its really a good feeling knowing you can f* around in the car and not break anything...id go big or go home...do it one the right way and be done with it. A moser rear wont mind your extreme shifting habits
Old Jan 10, 2007 | 03:33 PM
CamaroRacing12's Avatar
9" or 12bolt? which one is stronger?
Old Jan 10, 2007 | 04:09 PM
Capn Pete's Avatar
Bayer, you're playing with fire even with your car being stock. Put sticky tires on, run nitrous, you're only pouring fuel on the fire .
There is a thread around here (fairly recent) about a "Bullet Proof 10-bolt" ... you can read it and see what the concensus is. I think you might have to get used to working on the 10-bolt a lot if you want to be hard on your car with a lot of power. Breaking it will become inevitable. I didn't think it was that bad 'til I broke my 4.10's, and realized just how easy it can happen .
IMO, the 10-bolt isn't worth "investing" much money into. Fix as required, but ultimately, get a 12-bolt or 9" when you've had enough rebuilding the 10-bolt .
Old Jan 10, 2007 | 04:27 PM
JakeRobb's Avatar
Super Moderator
9" is stronger than a 12-bolt, but you'll never see the difference at that horsepower level. If you ever want to go 800+ to the wheels, get the 9". Otherwise, the 12-bolt is lighter and plenty strong.
FWIW, a 150 shot of nitrous doesn't add 150 to your peak. It adds the most power at a lower point in the rev range, and tapers as the revs go up. So even with a 150 shot, you'd never see 536/547 to the wheels. Probably not even 500/500.
It'd still be enough to tear a 10-bolt apart.
Old Jan 10, 2007 | 04:35 PM
reamo04's Avatar
id get the strange rear, if u cant do the rear rebuild urself, add a couple hundred onto that. I just started getting gear whine in my rear, so i'm saving up for a strange 12 bolt. I believe u can find them for 1800 at some places
Old Jan 10, 2007 | 04:50 PM
JakeRobb's Avatar
Super Moderator
1800 would either be used, or without some of the options you'd want on a street car (posi and 4-channel ABS, for instance).
Old Jan 10, 2007 | 10:49 PM
Bayer-Z28's Avatar
Originally Posted by Kredz28
........id go big or go home...do it one the right way and be done with it. A moser rear wont mind your extreme shifting habits
Yeah... I've been beating on it w/ street tires. I've broken em loose PLENTY of times, no whine so far. I've power shifted plenty latley, but I don't want to do it too much b/c I'm scared of breaking a BIG expensive part..
I remember the "Bullet-proof 10b thread. That was set UP! He did a great job on it. But another thing, the money he sank into that rear and the efort, he could have gotten a 12b Strange.
I think I'm just gonna throw a TA Girdle on there for now and save for the Starangest of Strange rears... ........... and keep the heavy/hard shifting to a minimum. -Changing the oil this weekend too. I've been putting it off for too long.
Old Jan 11, 2007 | 08:08 AM
ws6transam's Avatar
My 10-bolt lasted through hundreds of dragstrip launches, autocrosses, and a few track days, plus 138,000 miles of daily driving. The thing only failed after a summer's worth of 400RWHP dragstrip action, and even then it was just a simple crush washer that shattered due to severe wheelhop.
Get the stud girdle....save for the 12-bolt (or the S60 :thumbup: ) Call it good!
Just remember this: I consulted with Richmond gear engineers in 1999 and their official opinion was that when properly set up, the 10-bolt design was good to 400 RWHP, and after that, all bets were off.
Old Jan 13, 2007 | 07:39 PM
metallicsniper's Avatar
those prices you stated don't include labor, unless you are doing it yourself you can look to add about another 300. I won't run sticky tires on my car. i am in the process of buying my rear. don't waste your money on a 10 bolt. your just asking for trouble.
Old Jan 13, 2007 | 10:28 PM
godspeed1976's Avatar
Of Strange and Moser I definately think Strange has a much better deal for the money. It also seems to be a much more complete, and straight forward bolt in. If you are gonna run a power adder, and slicks I think an aftermarket rear is the way to go. I also saw that same new Strange for $1800, but can't remember where, It was new with posi, but I think is had no ABS (which is fine for me).
Figure out your target HP, or ET, and then you can figure out if a 12 bolt, or 9" is better for you. If you can't set a limit on power then the 9" is your only anwser that wont make you have to upgrade again in the future. If you can set a limit you can achieve it faster for less money by focusing on only the optimal parts you will need and not the ones that you don't.
I am upgrading my 10 Bolt personally, but I am not gonna run nitrous until my motor gives up the ghost, and I am building a new one. Untill then cam only, some ET Streets, lightened car and a 3200 stall should get me where I wan't to be and I should be able to do it on a modified 10 bolt. Its a toss up with the 10 bolt I am gonna make a $500 bet that I can save $ 1500 by not buying a 12 bolt or 9". If I lose then I will join the nay sayers.
Live and learn
Old Jan 14, 2007 | 11:04 AM
95firehawk's Avatar
Live and learn
Great reply! I am still on the fence on whether I want to try this myself or not.
Old Jan 14, 2007 | 11:32 AM
The Engineer's Avatar
With the M6 and shock from the launch you'll probably need an aftermarket rear-end. Whereas, the 10-bolt could possibly survive with an auto.
If you keep the 10-bolt, don't forget the ARP stud kit for the caps which will also help along with the other mods you've mentioned.
WD
Old Jan 14, 2007 | 01:17 PM
mdacton's Avatar
I would not spend any money on a 10 bolt if I didn't have to not even for the cover
I run a 9" with a spool and 35spline......you feel alot better knowing it wont break
Old Jan 14, 2007 | 01:28 PM
Zitty'sZ's Avatar
Don't waste your hard earned money on a junk rear, you can put $600 into a 10 bolt and you will have a $600 piece of junk rear! I was thinking of doing what you are thinking , but then I came to my senses and saved up and bought a strange 12 bolt with 3:73 's. The strange bolts in just like the stock rear with no modifications. It's your money but in the end I think you would better served to upgrade just one time and spend that $550 - $600 on something worth while. MY .02 cents.
