1998 Z28 with a Corvette LS1?
Old Jan 7, 2007 | 05:48 PM
MHChilds's Avatar
Does anyone know if any of the 1998 Z28's came with the Corvette LS1? When I purchase parts such as oil filters, temperature sensor, the ones shown for the 98 Z won't work. I have to order the parts for a 1998 Corvette. example, at Auto Zone the recommended oil filter is a (Fram)PH30. It is too big. I ended up using the (Fram) PH3506 for a 1998 Vette. I had the same problem when I needed a Temperature Sensor. I tried to get the block casting number, but you need to pull the engine to get to it. Thanks in advance for any response
Old Jan 7, 2007 | 05:57 PM
99SilverSS's Avatar
The LS1 is the same but the Vette has a different oil pan and filter. I don't know about the temp sensor. I know the core engine parts are the same, but for packaging from a C5 to a F-body would cause some parts to be different. This would be a better question in the LS1 engint tech forum.
Old Jan 7, 2007 | 06:24 PM
MHChilds's Avatar
Thanks 99SilverSS. You may have answered my question. I have the part number for the oil pan. I'll check to see if it is for a Z28 or the vette. It's frustrating. I keep forgetting to order parts for a 98 Vette and have to make the trip back to the parts store.
Old Jan 8, 2007 | 09:10 AM
AL SS590 M6's Avatar
Moderator
An LS1 with a Corvette pan won't fit in an F-body at all.
Old Jan 8, 2007 | 10:09 PM
Greed4Speed's Avatar
Go to a used car lot with a Z28 and I'm sure they'll tell you it has a "Corvette engine."
Old Jan 10, 2007 | 10:29 PM
pkincy's Avatar
The correct filter for the 98 Camaro is the 3506. The 30 was an LT1 filter.
Perry
Old Jan 11, 2007 | 12:48 PM
SSpdDmon's Avatar
Not all years were the same. The tune is different, the exhaust manifolds are different, and the cams were different in the early years. I don't recall ever seeing a C5 with an EGR system either.
Cams:
Dur, Lift, Lobe spread
F-body`98-`00
198/209 500/500 119.5
Corvette `97-`99
199/207 472/479 117
`00 Corvette
198/209 500/500 115.5
All LS1 cars `01 -up
196/207 467/479 116
If you need parts for your car and aren't sure because the Autozone computer is f**ked up, have them look up a '99 Z28. Chances are better the part will be the one you're looking for vs. looking up a C5.
Deadbolt24
Jan 19, 2015 01:29 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Deadbolt24
Dec 18, 2014 08:18 PM
Bearmans
Dec 3, 2014 05:28 AM
