Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Mallory 685 bad for opti?....
Old Jan 4, 2007 | 09:34 PM
69z-28's Avatar
i read a post by another member saying that the 685 box isnt good to constantly use with the Opti. i plan on using it for nitrous, with the retard and window switch capabilities but was wondering what people thought/heard/know about this.
Old Jan 4, 2007 | 10:02 PM
69gto96z's Avatar
I havent heard anything like that.
Old Jan 4, 2007 | 10:15 PM
No particular ignition box is bad for the opti. People just like to make unproven claims.
Old Jan 4, 2007 | 10:17 PM
69gto96z's Avatar
If shoebox said it, it must be true!
Old Jan 4, 2007 | 10:24 PM
Not really, but I know from running an MSD 6A for 6+ years that it's not bothering my opti. There's plenty of other people running ignition boxes, too.
Old Jan 4, 2007 | 10:35 PM
69gto96z's Avatar
Shoebox, where do you have your 6A mounted?
Old Jan 4, 2007 | 10:37 PM
69z-28's Avatar
yep yep. hmmm, well i guess screw it then. how about mounting it? i can rig it to activate the window switch and timing retard only when i arm the system correct? so then i can mount it under the hood since i wont manually need to retard the timing everytime then huh....
Old Jan 4, 2007 | 10:52 PM
69gto96z's Avatar
Yes you can set it up to retard the timing while spraying only.
Old Jan 5, 2007 | 10:43 AM
2000GTP's Avatar
I wouldn't put a whole lot of thought into it, I have also heard many claims about aftermarket coils destroying optis as well.
Old Jan 5, 2007 | 12:14 PM
01Z's Avatar
01Z
You are right that it is unproven but wrong about people (like me) simply liking to do it. I repeat empirical as well as logical statements from respectable people because I believe they are correct. I've quoted you time and again. I simply want to contribute, help and be part of the discussion. If my passing of an unproven claim occurs it is a mistake that I take seriously and try to correct.
Old Jan 5, 2007 | 03:02 PM
It is under the underhood fuse/relay panel. I had to kind of customize the mounting because the surface is not all flat. It's out of the way, though.
HectorM52
Jul 30, 2017 11:46 AM
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
Sergio
Jan 27, 2016 04:27 PM
ad356
Apr 11, 2015 10:30 PM
BIIZ28
Aug 20, 2002 10:26 PM
