front ride height for drag racing
Old Dec 18, 2006 | 04:33 AM
romoranger's Avatar
hey, i was just wondering if anyone knew how how or low the front of the vehicle should be in relation to the rear of the vehicle to be optimized for drag racing. if it helps to known my suspension set up i have, i have hals in the back with stock z28 rear springs and a dual air bag set up. in the front i have the hal r series (90/10) with 275lb springs. no front sway bar, rod end/rod end lca's as well. as of right now my front end is probably about 1/2"-1" higher than the rear.
should i lower it an amount, raise it, or does it really not matter a bit. any help is certainly appreciated.
Old Jun 14, 2007 | 05:33 PM
MTL_Z28's Avatar
I was curious about the answer for this.
Old Jun 27, 2007 | 12:09 AM
BMoney's Avatar
in my opinion you want the car to be level, as low as possible but still level front to back. cause you want the front end to come up for weight travel. and the lower the front is compared to the back, is just that much more the front end needs to travel to move the weight.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
Elcojoe
Nov 17, 2014 10:27 PM
