Help!!
Old Dec 17, 2006 | 08:40 PM
illwill's Avatar
Help!!
I just bought a 2000 3.8L camaro..... my cousin put 89 octane in it and now its jerking and back firing wat should i do
Old Dec 17, 2006 | 09:15 PM
AlfredB18's Avatar
That's not what's causing the engine to jerk...at least the gas being 89 octane, that is.
Old Dec 18, 2006 | 08:55 AM
MustangEater82's Avatar
the octane shoudln't have caused any problems.
If its only happened since the last tank of gas, I would just assume its a bad tank of gas(everynow and then you cna get a ****ty tank of gas, that has water in it)
I say try to run it down then get a new tankfull.
now if you still have other problems after that, check fuel filter, plugs/wires, cat.
then coils.
Old Dec 18, 2006 | 11:58 AM
2000GTP's Avatar
The octane should have no ill effect on the car. Bad gas, however, as already mentioned can definitely cause a world of problems. Is the SES light on? Was the car acting any differently before putting in the gas?
Old Dec 18, 2006 | 05:26 PM
oil pan 4's Avatar
Sounds all most like a tank of puke gas, every once and a great while diesel gets mixed with gas at the station on accident.
Old Dec 18, 2006 | 07:12 PM
illwill's Avatar
The SES light is on,, somtimes it blinks thats when the car jerks really bad..... i put some fuel injector and carb cleaner in and it smoothed out just a little bit but it still jerks and back fires
Old Dec 18, 2006 | 09:23 PM
Red98Maro's Avatar
I had the same problem and it turned out to be one of my coils, bring ur car to auto zone if theres 1 near u n they will plug into your computer under your dash, it sounds like u have a cylinder misfire, the computer will tell you which cylinder/cylinders r misfiring, then start by changing the plug, if thats not it try wire, if thats not it its most likely your coil, a new coil cost like 35 at napa
Old Dec 19, 2006 | 11:18 AM
2000GTP's Avatar
It definitely sounds like a misfire, but scanning the car will really give you some helpful clues. If you did indeed get some bad gas, that can easily clog up the injectors resulting in misfires.
