wiring reverse lights in B&M Pro Stick?
Old Dec 17, 2006 | 01:34 PM
Bolt-on Bob's Avatar
Just ordered a B&M Pro Stick and after calling the company, they said you can wire the reverse lights into it. The shifter hasn't arrived yet but I'm guessing it will require two wires. I know the two large ones, next to one another, are for the neutral safety switch. From the diagram:
http://shbox.com/1/1995_pcm5.jpg
does anyone know which two will be for the reverse lights? I'm guessing, of course, the light green one will be one but wanted to know if anyone, from having experience doing this before, knew what the other one was.
Thanks for any help!!
Old Dec 17, 2006 | 10:23 PM
The Lt Grn wire will be 12v and the other wire to the backup lamps should be a local ground that you should not have to worry about.
Roadie
Feb 16, 2015 10:34 AM
Cam's maro
Dec 29, 2014 08:44 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
jim88iroc305
Aug 13, 2002 09:24 PM
