Which way does a C-clip go in?
Old Dec 14, 2006 | 11:29 AM
wrd1972's Avatar
Axle C-clips have a flat surface and a more rounded surface.
I assume that the flat srface will face the spider gear.
Is this correct or the other way?
Old Dec 14, 2006 | 12:17 PM
The Engineer's Avatar
The C-clips are stamped-out in the manufacturing process (like flat washers) and that is what you're seeing (somewhat rounded on one side and flat on the other). There really isn't any correct, or wrong way to insert them. However, you can look at the old wear marks (round ring for the axel tip, flat for the spider gear) and put them back in the same way.
WD
Old Dec 14, 2006 | 01:45 PM
wrd1972's Avatar
Unfortunately I have had the c-clips out many times so I cant verfy the original orientation. I just bought new ones and want to get it right if there is a right.
kevm14
Aug 2, 2006 10:17 PM
69gto96z
10
Mar 28, 2006 12:46 AM
maksik7
Jun 16, 2005 03:52 PM
VILeninDM
Jan 26, 2005 11:41 AM
kmanRS/SS
Classic Engine Tech
Nov 5, 2003 09:01 PM
