Moser 9in Now Seems Lower
Old Dec 7, 2006 | 05:17 PM
30th6's Avatar
Back In The Summer I Put A Moser 9in In My Car. It Seems Like My Car Bottoms Out On Every Little Bump Now.i Checked The Bumpstop And Its Only 2 1/4in. Away From My Axel Tube.is That Normal Only Thing I Put In Different Was A Umi Tunnelbrace Adjustable Tourquearm. Ive Tried Puting On New Shocks But It Didnt Help.i Also Have A Wheelhopping Issue I Think Its Because The Car Sits Lower And The Lca Angle Is Diferent. What Do Yall Think?
Old Dec 8, 2006 | 08:50 AM
Hint: If you turn off the caps lock, the system will not make your post look odd, with the first letter of each word capitalized.
What shocks and springs are you using? Sounds like they may bo too soft. Did you reinstall the rubber upper spring seats? The 9-inch axle tubes are larger in diameter than the stock tubes, so that would explain away a small reduction in the distance between the jounce bumper and the axle housing.
Old Dec 11, 2006 | 02:16 PM
30th6's Avatar
I put the stock springs and shocks back in but ive put in new shocks sense then there summit 3 way adjustables.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
