Stuck in cell 16 128/128 at Idle or at any time TPS=0
Old Dec 6, 2006 | 04:11 PM
xxsaint69x's Avatar
so i finally got tired of my car runing rich as hell (12.1s on my wideband at idle) I noticed that i am stuck in cell 16 and my blms are at 128/128 and my 02s do not go up and down..just sit at .900s....It seems like they are locked or something?!~ i dont know...give it little gas and everything works great, o2s start to move and blms go to 127ish..let of the gas..and back to cell 16 128/128 and .900s on the o2.....WHAT IN THE WORLD?!
Never had that problem when the car was na..i would usualy have a split blm and bottomed out blm..lol arrr! help
Old Dec 6, 2006 | 06:07 PM
94 NO TOP Z's Avatar
Mine has done the exact same thing after I put the 72 lb injectors in. I've played with inj constant, voltage, etc in the programming and it always idles at 12.5 AFR and the O2's never move at idle. I don't know if the injectors are so big they just can't squirt that small amount of fuel or what.
Old Dec 6, 2006 | 06:59 PM
97WS6Pilot's Avatar
Are you using a MAF or Speed Density? I have really good luck using a descreened MAF and limiting the BLMS to +-3. I richened the MAF table up just a hair in the cam surge areas. It runs at a perfect 14.7 all the time except at WOT then it goes to 11.8. This method completely takes the O2's out of the equation but still allows you to run closed loop.
Another thing that can cause low AF ratio at idle is turbulence in the intake air near the MAF. Hope this helps.
Old Dec 6, 2006 | 08:49 PM
xxsaint69x's Avatar
can u send me your file so i can take a look at it what u have set different?
Old Dec 6, 2006 | 08:53 PM
xxsaint69x's Avatar
there has to be something we can change to get rid of this bs.
Old Dec 6, 2006 | 09:23 PM
97WS6Pilot's Avatar
My files are Tunercat for OBD2. I doubt you can even open them with your software. The files end in .cal.
Are you using MAF or SD? MAF Location? Bypass Location? Need more info.
Old Dec 6, 2006 | 09:56 PM
xxsaint69x's Avatar
MAF is in stock location..bypass is before the MAF by the intercooler. Using MAF ofcourse
Old Dec 7, 2006 | 01:08 AM
Lisa33's Avatar
Have you checked TPS volt at idel?
Old Dec 7, 2006 | 10:31 AM
xxsaint69x's Avatar
its within specs
Old Dec 7, 2006 | 05:01 PM
97WS6Pilot's Avatar
It sounds like it is in WOT (PE) mode at idle. Check your "%TPS Threshold for WOT vs RPM" table. It should be 66% from 0 rpm all the way to 2800 Rpm. This table tells the computer to go to WOT at 66% throttle position in those rpm ranges. These are the numbers in my table.
%TPS RPM
66.0 0
66.0 400
66.0 800
66.0
66.0
66.0
66.0
66.0
57.0
48.0
37.9
28.1
28.1
28.1
28.1
28.1 6000
28.1 6400
Old Dec 7, 2006 | 08:29 PM
xxsaint69x's Avatar
%TPS RPM
66.0 0
66.0 400
66.0 800
66.0
66.0
66.0
66.0
66.0
57.0
48.0
37.9
28.1
28.1
28.1
28.1
28.1 6000
28.1 6400
nope thats not it..and i tired to make it do that actually and it did not move the aFR AT ALL
Old Dec 7, 2006 | 08:57 PM
byrons1502's Avatar
i had the same problem with the powerdyne file that they sent and told me not to mess with. i had changed everthing i could think of except the maf calibration. was told that was black magic and could not be modified. but after 56 plugs in three days(and alot of busted knuckles and cusswords) i changed it anyway. i went from under 10.1 afr to almost 13.1 with minor tuning. save your old file so you have backups but that was the best thing i ever did. went from stuck 108 and 80 both banks and stuck in cell 16,17,18 to heaven
Old Dec 7, 2006 | 09:06 PM
97WS6Pilot's Avatar
Any chance it could be going open loop at idle?
Old Dec 7, 2006 | 09:50 PM
xxsaint69x's Avatar
no, its in closed loop..checked via datamaster
HectorM52
Jul 30, 2017 11:46 AM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
tds1213
Nov 27, 2014 12:55 PM
