Rear mount Turbo without changing mods???
Old Dec 4, 2006 | 10:11 AM
hektyk's Avatar
Just wondering if I could run one without changing my current mods. Would it improve my Hp by a bit? Is it worth it? I don't wanna go in and change my cam and **** to run one ya know. Thanks Fellas
Old Dec 4, 2006 | 10:22 AM
detroit1994z28's Avatar
Hey Buddy. Your in luck cause I'm running a similar set-up with the STS kit on my 94 z28. I'm also running the lt4 hot cam with my STS kit with the stock heads. Headers and I made over 100rwhp gain @5psi. Just remeber that you will need the ls1 STS kit since your running headers. The lt1 kits will not clear. It's the same exact kit except they route differently.
Old Dec 4, 2006 | 12:04 PM
hektyk's Avatar
Around what Hp and Torque are you running?
Old Dec 4, 2006 | 12:08 PM
LOW boost 377/378@5psi. High boost 400/408@7psi with Meth inj. On a mustang dyno. That was with a 4:10 gear ratio thow. The new 3:50 ratio makes a huge difference - it allows the turbo to spool allot allot longer
Old Dec 4, 2006 | 12:15 PM
hektyk's Avatar
Thumbs up
Thats with the mods also. Hell I figured up that I was over 400 Right now with just the current mods. Thanks for the info by the way.
Old Dec 4, 2006 | 12:19 PM
Yeah those are with the mods. You should be around 280-290rwhp with your mods.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
