200k, stock bottom end, 150 shot?
Old Dec 2, 2006 | 09:53 PM
95 Mystic TA's Avatar
I have been running 100hp shots for awhile via a NX wet kit and the motor has 205k miles on it. The plan as of now is just a decent "weekend" car that will go through a bottle maybe every other month or so. I'm now looking for a cam, and LT's. I'm trying to do a relatively "thrify build" so I would rather not have to do the bottom if it's not absolutely neccesary.
Is a 100 shot feasible with the motor staying together? What about 150?
Old Dec 3, 2006 | 12:33 AM
bombebomb's Avatar
With 200k on it, id say you will blow it up very quickly, and putting a cam in it, your asking for a spun bearing with them miles.
Old Dec 3, 2006 | 12:59 AM
Daniel6718's Avatar
cam will most likely kill the bearings....as for n20 make sure you have good fuel system, and pull timing and youll be fine!!!
wouldent hurt to do a compression test first...
Old Dec 3, 2006 | 11:50 AM
2000GTP's Avatar
Both a cam and nitrous is pushing it in my opinion. If you do go forth with it, I would keep a rebuild in mind and start planning for it.
Old Dec 3, 2006 | 11:54 AM
Thanks everyone. I guess I know what I need to do.
Old Dec 4, 2006 | 08:37 PM
Hawk's Avatar
two words from a fellow juicer...
HELLZ NO!!!!!!!!!!
Old Dec 9, 2006 | 07:35 PM
DrewHMS97SS's Avatar
Old Dec 11, 2006 | 06:44 AM
Z-RATED94's Avatar
Just leave well enough alone. Or you'll be .
Old Dec 11, 2006 | 08:13 AM
Javier97Z28's Avatar
Moderator
Pill it till ya kill it, then rebuild and choose the cam you wish.
Noer
Feb 28, 2015 11:29 AM
Killer94z
Jan 13, 2015 12:06 PM
Collector Car
Jan 5, 2015 10:58 AM
97 RedSS
Jun 10, 2003 07:58 PM
