Rear End??????
Old Dec 1, 2006 | 09:25 PM
JC95Z's Avatar
Rear End??????
I have a 95 chevy s10 that i believe comes stock with a 373 10 rear end. Will these gears work in my 1995 z28 10 bolt rear? The s10 has a sbc in it right now i just plan to sell it and i want to put 373's in the camaro ne way so i figured i could jus swap them. Anyone know if this will work?????
Old Dec 1, 2006 | 09:27 PM
Dave89IROC's Avatar
is the s10 2wd? if yes, then yes, the gears will work(might need to swap the carriers as well though[series 2/3])
some of the 4x4 s10s got the 8.5, not the 7.5
Old Dec 1, 2006 | 09:34 PM
JC95Z's Avatar
yeah it is a 2wd. I thought it would but didnt want to tear it apart and find out the hard way.How will i know if i need to swap the carrier as well?
Old Dec 1, 2006 | 09:39 PM
Dave89IROC's Avatar
what gear is it the camaro? what gear in the s10?
Old Dec 1, 2006 | 10:35 PM
JC95Z's Avatar
Whatever came stock in a 95 z28 i believe its a two somethin or another. The s10 has a 373 im pretty sure of.
Old Dec 2, 2006 | 01:49 AM
formulalt4383's Avatar
Check your RPO's cause if its a 2 series you will need to swap out the carrier too or use a spacer (which I don't recommend). You would also need to buy a 3 series reluctor ring cause I don't believe the S10's use them on the differential like f-bodys.
Old Dec 2, 2006 | 10:42 AM
Severous01's Avatar
take the torque converter out as well. it's a 3200 stall and will work wonders in your z/ta...whatever 4l60 ya got.
Old Dec 2, 2006 | 12:16 PM
Z-RATED94's Avatar
It will help a little but I wouldn't count on it lasting under hard driving conditions. And if it takes a dump it might hurt the tranny too.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
