42lb bosch injectors
Old Nov 17, 2002 | 10:11 PM
madlasher's Avatar
hey guys Im a newbie,and need some help.Im going to install a set of 42 lb bosch injectors on my LT1,Im using Tunercat and was wondering if the only thing that I have to change is the injector flow rate in the constants table to 42 to make them work.If so could someone let me know,or if not please help me out on this one.
later... Keith
69 camaro with LT1 & 4L60E
Old Nov 17, 2002 | 11:03 PM
Dan K's Avatar
If you're using a speed density computer, yes.
If you're using a mass air computer, then you'll need to change the injector offsets as well.
Old Nov 17, 2002 | 11:09 PM
madlasher's Avatar
Im speed density right now with the stock pcm,but I plan on installing a supercharger,and hooking up the MAF in the near future,any idea what the constants need to be changed to?
thanks...Keith
Old Nov 18, 2002 | 05:46 PM
Dan K's Avatar
Sorry, I've never seen offsets for a 42 before.
Old Nov 18, 2002 | 07:56 PM
madlasher's Avatar
anyone else??????
Keith
Old Nov 23, 2002 | 09:16 PM
Dan K's Avatar
I found the offsets for Lucas 42# injectors. Not sure if they're the same as the Bosch 42's or not...but I'm guessing so.
Check out Christian Millards site at http://carprogrammer.com/Z28/PCM/Injector/injectors.htm
Old Jun 23, 2003 | 07:58 PM
TriPinTaZ's Avatar
The voltage #'s do not all match up with my 97.LT1 file. I have some voltage #s that that chart does not have (Example18.4) and it has some voltage #s that I do not have.
I need the offset #'s for 42 Lb lucas/delphi .009 injectors. Anyone know where to get thesE?
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
