Plugging the Bung?
Old Nov 29, 2006 | 08:45 AM
19z28camaro02's Avatar
Plugging the Bung?
If you run an 02 sim, and dont replace that specific section of exhaust, what do you do with the bung from the sensor?
Old Nov 29, 2006 | 02:42 PM
LT1 POWR's Avatar
Are you talking about on a stock or stock style setup. Why are you deleteing the rear O2 sensors?
You can either cut off the wires on the O2 sensors and leave the actual sensor in there or you can put a plug in there.
Summit sells O2 sensor plugs or i'm sure a hardware store would have something that will work.
http://store.summitracing.com/egnsea...nresults=false
Old Nov 30, 2006 | 04:26 AM
2000GTP's Avatar
I heard of someone threading spark plugs in there as a temporary fix which became a permanent fix.
Old Nov 30, 2006 | 05:54 PM
The threads are M18x1.5. Just get a hex head plug and screw it in.
http://store.summitracing.com/partde...part=ngk-91301
Old Nov 30, 2006 | 07:52 PM
MysticTeal95Z28's Avatar
For my Mufflex Y-Pipe, which had hook ups for the 3rd and 4th o2 sensors (my car only has 2 o2 sensors) I threaded in some big tractor-like spark plugs since the designated bung plugs that O'Reilys had wouldn't fit in there since the bungs were "off-sizes."
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
