Middle Atlantic New Jersey, New York, and Pennsylvania
DIY porting!
Old Nov 24, 2006 | 05:38 PM
Projectz28's Avatar
Moderator
DIY porting!
What do ya think? Its almost like I knew what I was doing huh?
http://web.camaross.com/forums/showthread.php?t=486480
Gonna try my stock LT1 intake next.
Old Nov 24, 2006 | 10:04 PM
Schweet97Z's Avatar
now do mine!
Old Nov 25, 2006 | 06:22 AM
Projectz28's Avatar
Moderator
Originally Posted by Schweet97Z
now do mine!
Harold i am going to try the LT1 next. I changed my mind and decided to do all my "testing" on my LT4.
I'll shoot you some pics when I finish the LT1. Probably not for a few weeks though. This crap take some serious man hours. I have just over 4 hrs in those and that is only 4 ports... only 4 more to go
Man the DUPE factor is going to be crazy on you
Old Nov 25, 2006 | 07:14 AM
Schweet97Z's Avatar
lol yea i know metal work takes awhile....your lt-4 looks good!
Old Nov 25, 2006 | 07:45 AM
97TransAm's Avatar
Bastard.
**ron goes outside and kicks a tire on the 97TA.**
Old Nov 25, 2006 | 03:28 PM
Pampered-Z's Avatar
Nice job. Few thoughts.
1) Don't forget to open the from up for a 58MM or monoblade.
2) For a dry intake you want to polish it all out so it's nice a smooth. My insodes look like my outside, I finished it at 1,200 Grit. If your going to spray and not use a fogger type set up you want it a bit ruff so you get the air to tumble to help mix the airfuel and also prevent puddling.
3) When I showed my intake to my friend that builds motor he suggestest adding a bevel to 1+2 runners to aid the front cylinders from going lean as the air has to make a tight turn after the throttle blades. Now I have no proof if this is needed or actually helps. But if he knows enought to build 500CI prostock motors I listened.
JB
Old Nov 25, 2006 | 09:16 PM
Projectz28's Avatar
Moderator
JB
I plan to open up the front for a 58... that i just dont own yet. I need a good template first or some way of marking the correct opening to make.
I never heard of polishing the intake ports. I alwas thought you were supposed to leave them with the rougth finish. When I do put the squeeze on it I will run a max of 200 wet probably thru a set of nozzles up in the elbow. Havent decided for sure though. I still need to work on the finish here. They are only finished with 80grit right now. I will finish them off with a 120 flapper wheel and see how that finish looks. I can always polish them to a mirror finish with the cross buffs if needed.
Old Nov 25, 2006 | 09:17 PM
Projectz28's Avatar
Moderator
oh, and I didnt look at the LT1 but the LT4 already has a bit of a bevel in it. The walls are actually picthed toward the intake opening up front. If you werent looking for it you would never notice it, but its there.
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
