What would you do?
Old Nov 24, 2006 | 11:08 AM
350Z's Avatar
What would you do?
I'm thinking about a new motor for my car...currently has an L98 with mods in the sig...the old engine put 350hp to the wheels. The engine runs fine but I want a little closer to 500rwhp. I got AFR heads that could be ported....so I was thinking a forged stroker short block would be the way to go..so my question is if you had a budget of around 4K to spend on a new power plant for your car what would you do, stroker, lt1, ls1...?
thanks! 350Z
Old Nov 24, 2006 | 11:43 AM
2000GTP's Avatar
To get 500hp at the wheels NA, it is going to take a very aggressive cam and heads. The streetability and fuel economy of your car will go down the drain pretty quick. I would consider doing some sort of forced induction. Since your budget is around 4K, that will knock out a turbo or supercharger though. Why don't you just throw a 150 shot on top of the motor you have now and call it a day.
Old Nov 24, 2006 | 12:01 PM
chevycamaro210's Avatar
get the ls7 motor
Old Nov 24, 2006 | 12:03 PM
WS6NIGHTMARE's Avatar
Originally Posted by chevycamaro210
get the ls7 motor
Didnt you see where he said about 4k to play with?
LS1/6 FTW!
Old Nov 24, 2006 | 12:30 PM
Compstall's Avatar
Ditch the FI, sell it and put it towards a good carb setup.
Old Nov 24, 2006 | 03:33 PM
350Z's Avatar
I thought about putting a blower on this motor or a 150 shot BUT...I don't think the stock internals would survive...
Old Nov 24, 2006 | 03:49 PM
2000GTP's Avatar
Well, you could keep the topend the same and put in a forged shortblock, that will easily keep you in the confines of your 4K budget. Then put a 150-200 shot on top of that. Then you have a car that will make 500rwhp at the touch of a button and you will not sacrifice streetability, emissions, or fuel economy.
Old Nov 24, 2006 | 07:28 PM
Compstall's Avatar
You've already got good heads, you could have them ported, add cam and a mildly priced stroker kit along with the carb setup as I mentioned. I don't think you'd be too far off from 500 at the crank. Hell, those Hot Rod mag guys do it all the time with their setups, might be good to take a look at some of their setups in their magazines and see what you can come up with.
...and $4k won't get you a 500hp LS1 obviously. Good stock engine alone will break the budget. I think you've got a good start with some of your existing parts.
Old Nov 24, 2006 | 11:36 PM
350Z's Avatar
I know there's still some power to be had in the heads...I have an XFI cam in it now thats pretty agressive...I was thinking of buying a forged stroker short block then using my heads (after porting) and the miniram....I just don't know of alot of good stroker short blocks out there...
Old Nov 25, 2006 | 02:06 AM
2000GTP's Avatar
Try Victory Racing Engines, they sell several 355 and 383 shortblocks built and ready to go. They may be able to tailor one to your specific needs also, worth a shot to ask. www.victoryracingengines.com
Old Nov 25, 2006 | 08:58 AM
350Z's Avatar
I looked at thier web site....looks like thery're LS1 and LT1 engine builders...didn't see any Gen 1 sbc stuff.....been looking at speedomotive....
