ls6 or ls2 engine swap
Old Nov 22, 2006 | 05:22 PM
rchops33's Avatar
I realize that the v6 to LS1 engine swap is quite involved and expensive...but that doesn't matter to me. How about a swap to an LS6 or LS2? Anyone have any light on the subject as far as what's involved? Or is it pretty much the same as the LS1 conversion? My main concern is the rear end, I'm hoping that it can stay the same.
Thanks!
Old Nov 23, 2006 | 06:51 AM
M5camaro's Avatar
I think that you would at least need to swap to a posi rear. How many miles does your car have? If the mileage is high, the rear might not hold up anyway.
Old Nov 23, 2006 | 09:40 AM
Jun10rp's Avatar
If your talking about the rearend in your v6 its not gonna hold up I put a supercharger on my old v6 and it went out within a month so I dont think it would work.
Old Nov 23, 2006 | 10:20 AM
2000GTP's Avatar
The factory rears aren't exactly known for being the most durable. Along with the LSx swap can come the potential headache of a blown rearend. Its something to keep in mind and be prepared for when the time comes. I would say at the very least try to get a used rearend with 3.23 or 3.42 gears and a posi. That will really complement your motor swap nicely.
Old Nov 27, 2006 | 10:31 PM
rchops33's Avatar
What's the rear end gear ratio on the v6?
Old Nov 27, 2006 | 10:47 PM
rickjames343's Avatar
Most had 2.73s, but correct me if im wrong
Old Nov 27, 2006 | 11:04 PM
Klypto's Avatar
mine had 3.08
Old Nov 28, 2006 | 07:34 AM
2000GTP's Avatar
I believe the automatics had the 2.73s and the manuals had the 3.08s. The easy way would be to check your RPO codes in the door jamb or glove box.
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
Old Nov 28, 2006 | 07:39 AM
FS3800's Avatar
there are some factory freaks out there that have 3.42s with an auto, and not Y87....
he should definately check his RPO codes
Old Nov 28, 2006 | 11:38 PM
shock6906's Avatar
If you're willing to do the LS anything swap, I'd imagine you would be willing to swap the rears. Seems like it'd be the least of your difficulties.
Old Nov 29, 2006 | 10:31 AM
2000GTP's Avatar
Exactly, that is what I was thinking. When you do a swap like that, sometimes it is easier just to find a wrecked donor car and swap over the entire powertrain.
Old Nov 29, 2006 | 05:45 PM
rchops33's Avatar
Good point, but I plan on buying a remanufactured engine and tranny rather than a doner car.
Old Dec 6, 2006 | 10:16 PM
BandDirector Blk98ZM6's Avatar
A swap to an LS6 will be almost exactly the same as an LS1 swap. I swapped my LS1 for an LS6 and it was all but a direct bolt in swap. However, I didn't start with a V6 when I did my swap, so I have no knowledge from that standpoint.
Old Dec 10, 2006 | 01:09 PM
byrons1502's Avatar
the rear ends are the same both have 7 5/8 inch rearends. swapping the rearend will do nothing. changing the gears and carrier to a newer 3.42 posi would make the car a whole lot happier though. new axles are cheap insurance. you will break it eventually unless you spen some money. check out the drivetrain forums
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
Cam28_boy
Aug 6, 2002 08:40 AM
