hp estimate
Old Nov 15, 2006 | 07:15 PM
racer96's Avatar
hp estimate
i am gonna need for a fuel system. ill give you everything i know about the setup.
383 stroker block out of a 94 z
lunati forged h beams and crank
je blower pistons 8.25 compression
high volume oil pump
electric water pump
comp cam special grind 236/248 579/579 114
lt4 intake
lt4 heads bee hive springs 1.6 rr
d1sc procharger twin high flows gonna run around 20 psi hopefully
headers full loudmouth exhaust
will be getting a dana60 hopefully it is quiet hahah
full suspension
spec stage 4
any help is appreciated, or fuel systems i would like the most out of this setup and will push it hard! thanks guys
Old Nov 15, 2006 | 09:16 PM
ramermanz28's Avatar
Don't skimp on the fuel system or you'll pay, trust me I know. Spend alot of time on the fuel system.
Old Nov 15, 2006 | 10:43 PM
racer96's Avatar
yes i had bought this engine off a board meber. it is all brand new, should i get new heads or new pistons. how hard would it be to get new pistons in there. the engine is in a crate still.
Old Nov 15, 2006 | 11:02 PM
roguedriver's Avatar
I would imagine a dual in tank pump setup like the Racetronix dual 255's, 60# injectors, a good regulator and stock fuel lines should be sufficent with some room to breathe.
Ken R.
Old Nov 15, 2006 | 11:42 PM
racer96's Avatar
i cant find the racetronix dual 255's is there a link or can some one give me a link thanks.
Old Nov 16, 2006 | 01:05 AM
ZBLKHELLRZR's Avatar
Here you go. Select racetronix on the left of the screen.
http://www.lonniesperformance.com/
Old Nov 16, 2006 | 09:24 AM
CrazyLT1's Avatar
With that set-up, running correctly, your prolly lookin at 650-700 RWHP
Old Nov 16, 2006 | 12:18 PM
racer96's Avatar
thanks for the link, i hope i am in that horsepower, thats what i where i would like to be!
Old Nov 16, 2006 | 08:35 PM
TransAm396's Avatar
......20psi on beehives?? good luck with that one.
Old Nov 16, 2006 | 09:15 PM
racer96's Avatar
Originally Posted by mgray
Is it in writing or verbatum this 8.25 compression ratio?
thjat is what he told me the other day, i am going to call the guy and ge the exact part number of the pistons. 8.25 seems very low. i see some guys running lower but i dunno i hope it is around 9:1.
Old Nov 16, 2006 | 09:16 PM
racer96's Avatar
ya i think i am going to run 15 psi. i thought u could run more on pump gas but it should get me close to my goals.
Old Nov 17, 2006 | 09:42 AM
Kredz28's Avatar
i would ditch the high flows if you are going to run more than 15psi...
Old Nov 17, 2006 | 12:51 PM
CALL911's Avatar
Agreed. After about 8#'s or so, the twins just can't keep up. I highly reccomend a FMIC. Or if nothing else, look into running a methanol injection system or race gas.
Properly setup though, if you max out the D1SC (my guess is that you won't see over 18#'s of boost), with the setup you said, properly tuned, it should do an easy 650-700 RWHP if not more.
Also, if possible, you may want to consider going with a FAST system to properly run everything.
BTW, I dyno'd my car at 15.3#'s of boost, and it was all done with pump gas on the stock PCM. If I had the FAST system in place of the PCM, I could have run more boost, and without a doubt gained more HP, still running off of pump gas. Video of my tune here>
Click here to see Video
Old Nov 17, 2006 | 02:27 PM
racer96's Avatar
Call 911 I Have Watched Your Video A Few Times Before Actually, Pretty Sweet Setup. How Do Those Meth Injections Work, Do They Automatically Turn On When U Hit Higher Boost Or What. I Havent Read Much About Them.
Old Nov 21, 2006 | 10:58 AM
CALL911's Avatar
I am sure you could rig it to come on at a certain amount of boost in the same way I have my 2nd fuel pump kick on from a HOBBS switch at 4#'s of boost.
I am by no means an expert on the details of how they turn on though since I do not run Meth inj. in my car.
Rich (rkause) would be the best one to ask for details on this. He is IMO the most knowledgable person in this forum.
