SES light, then it goes away, no code?
Old Nov 17, 2002 | 01:34 AM
Achilles97's Avatar
Question SES light, then it goes away, no code?
I was on my way home from the track, I floored it through 2 gears to get on the interstate, then 15 seconds later I got the SES light. I notice the exhaust sounded a little different so I suspected a header was leaking.
I got home, turned off the car, turned it back on, and the SES was gone. I drove around the block a few times and no SES. I still think it sounds like the header is leaking...
I scanned the car with TTS DataMaster and there was no code. I thought that the SES trips a code, and it doesn't go away. Does it go away when the SES turns off?
I will check for exhaust leaks tomorrow. Do you think that sounds like a reasonable guess at what the problem could be?
Thanks!
Old Nov 17, 2002 | 02:34 AM
Dr.Mudge's Avatar
It will go away if the problem goes away, some codes sit in the computer longer however.
Run FreeScan or Datamaster and repeat the situation, if you get an O2 Sensor Lean code then you most likely do have an exaust leak, which I've had, and it liked to show up I suppose around 4500 RPM or so. If thats the case you should also experience a serious power loss when the code hits.
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
