Converting my 94 Analog cluster to Digital 97 one..
Old Nov 12, 2006 | 01:44 AM
Gun5's Avatar
Im sick of these damn analog clusters where the trip meters dont work im just gonna do the damn digital conversion do i need to get the 97 connection below?
Old Nov 12, 2006 | 02:27 AM
Gun5's Avatar
bump heres one i can get..
he says its out of a RS v6 car 97.... but it goes to 150mph it should work still?
Old Nov 12, 2006 | 05:04 PM
sbca96's Avatar
I posted up a thread about putting a Firebird dash in a Camaro, you might do
a search for that. The replies that I got should apply to you as well.
Tom
Old Nov 12, 2006 | 05:16 PM
rickjames343's Avatar
I don't think any v6 came with a 150 mph speedo...only the z28s and SSs. correct me if im wrong though.
Old Nov 14, 2006 | 01:09 PM
JJJ93z's Avatar
Correct, if it came with Z rated tires out of the factory then it came with a 150 mph cluster
Old Nov 27, 2006 | 01:15 AM
Gun5's Avatar
bump anyone else whos done this tips on changing wires from one connector to another?? im getting the console this week
Old Nov 27, 2006 | 10:27 AM
CALL911's Avatar
You can always just swap to the digital 97 style Firebird dash like I did in my 94 Formula. It was easy and only took me 10 minutes. No wire changing, just pull the stock one out and put the new one in.
Old Nov 27, 2006 | 06:05 PM
Gun5's Avatar
im getting a 97 camaro digital cluster... its the same thing as the firebird one (same shape) they put the same thing it both parts i believe if i look at the part numbers your telling me its a clean swap? no connector change
Old Nov 27, 2006 | 06:18 PM
Z95m6's Avatar
Yes it'll just plug right in and work fine.
Old Nov 27, 2006 | 06:25 PM
Gun5's Avatar
alright cool hopefully it works that easy I had some white face gauges that I wanted to put on it but im scared i screwed up my last cluster putting them on (MPH) also some of the light for the needles shows through the white faced gauges making a annoying glow anyway to get rid of that?
Old Nov 27, 2006 | 10:13 PM
WHITE94Z28's Avatar
So if I buy a 97 cluster it will bolt right into my 94 with no modifications to the dash or wiring?
Old Nov 27, 2006 | 10:46 PM
Z95m6's Avatar
No. I'm not even going to begin to explain the differences and why, because a simple search would answer this.
Old Nov 27, 2006 | 11:59 PM
Gun5's Avatar
rofl
Old Nov 28, 2006 | 10:00 AM
CALL911's Avatar
YES.
I don't know what the research is telling anyone else, but I can say that all I had to do was pull out my stock one out of my 94 Formula, and I just pushed in the new one and screwed the dash back together (NO ADAPTERS NEEDED OR SPLICING WIRES), you just plug in the new one just like the old one.
The only thing I had to do was get my mileage notorized and had a company enter the correct mileage into the digital dash.
Old Nov 28, 2006 | 06:56 PM
WHITE94Z28's Avatar
I have searched about this in the past but was under the assumption that I would have to do the wiring changes listed in this post.
So when I read this post it appeared that I could just install a 97 cluster without changing the wiring. Just thought I would ask.
