Very quick T56 swap question *Swapping it right now*
Old Nov 11, 2006 | 07:59 PM
Drowned's Avatar
Exclamation Very quick T56 swap question *Swapping it right now*
On the guide by Alex Afrashteh, I'm wondering about this step:
Remove steering knuckle and steering column. A bunch of wires need to be disconnected. There are three bolts in the frame and two big bolts that hold the column. There will be a plastic line with a metal wire in it that connects the shifter assembly to the steering column - this is the mechanism that prevents the key from being turned unless the car is in park - remove it.
Do I just unplug the plastic line with metal wire from the mechanism on the steering column or do I need to something else... I pulled it out but I'm not sure if that's the only thing I need to do on this step, perhaps disconnect the mechanism or remove all of it...
Please help
Old Nov 11, 2006 | 11:15 PM
MEAN LT1's Avatar
Please help
The line going up the steering column needs to come off. You wont need it anymore. I took out my steering column just to make it easier, some people were able to work around it.
Old Nov 12, 2006 | 09:27 AM
Drowned's Avatar
Thanks for the reply! I just yanked it off from the mechanism in the steering wheel, I had to drop the column a bit but not take it off...
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
HectorM52
Jan 31, 2015 07:29 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
nballisru
Dec 14, 2014 05:01 PM
