sloppy steering wheel
Old Nov 11, 2006 | 07:46 PM
davidarel's Avatar
I have a 99 T/A and the steering wheel wobbles. I know on the third gen camaros that you have to remove the steering wheel and the blinker assembly and then tighten the three torx screws to fix the problem. Is it the same on the 4th gens? I removed the air bag assy. and there is a whole lot more going on inside this wheel. Should I let a shop do it or am I making it harder than it really is.
Old Nov 14, 2006 | 04:24 PM
Compstall's Avatar
I believe GM hasn't changed much in how the steering wheels attach on their cars in a long time. I bet the setup is similar/same. Shouldn't be too hard as long as you keep track of where everything came off.
Old Nov 14, 2006 | 06:48 PM
davidarel's Avatar
I kind of figured that. I was mainly concerned about the airbag coil that sits behind the steering wheel. Also, a buddy of mine has a 4th gen column that is torn apart and I couldn't see anything that looks like the assembly on a 3rd gen. I really don't want to tear it apart without knowing what to look for.
Old Nov 14, 2006 | 07:20 PM
razor02097's Avatar
you mean the steering wheel is loose like it would pull off or is the steering sloppy?
Old Nov 14, 2006 | 07:25 PM
davidarel's Avatar
The steering wheel wobbles from side to side.
Old Nov 15, 2006 | 10:52 PM
matLT1's Avatar
I had that problem in an old car of mine. Like you said above, I just tore into the column and tightened the torx screws.
jasonduaine
Jun 4, 2015 09:29 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
