How much timing for 18psi
Old Nov 9, 2006 | 08:14 PM
xxsaint69x's Avatar
how much timing should i throw at it?
8.5 compression and 18psi on 93 pump gas.
also what A/F ratio should i be shooting at...12.00 good enough?
Old Nov 10, 2006 | 12:16 AM
Lisa33's Avatar
Oure setup
8.5 comp, OBX4"FMIC and a M10 nozzle widh water/alky.
timing is 26degrees and A/F 11.7-11.9
have tried a 60hp N2O shot also widhout any spark retard.
Old Nov 10, 2006 | 08:06 AM
xxsaint69x's Avatar
sweet..i don thave any alky so ill stick with around 20
btw how much boost do u guys think ill gain goin from a 4.20 pully to a 3.70 pully..the crank is stock at 7.65 i believe....making 13-14psi with it..
Old Nov 10, 2006 | 03:35 PM
Schurters LT1's Avatar
I would start around 18* and work your way up from there.........better to be safe......
You should look into getting ALKY if you want to run that kinda boost and timing all the time......
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
