Smog Test Failed, Opinions??? +pics
Old Nov 1, 2006 | 06:28 PM
dst's Avatar
dst
Angry Smog Test Failed, Opinions??? +pics
Only failed the NO, no engine light and she seems to run OK.
Here are pictures of my test results
FIRST TEST
SECOND TEST AFTER HIGHER RPM DRIVING
The scans are not very good, the NO reads 874 @ 15MPH on the first test and 903 @ 15MPH on the second, max is 424
A little info, V6 5spd 1997 144k miles, CAT replaced 2 years ago and passed then no problem.
Old Nov 1, 2006 | 07:31 PM
OBE1 95Z28's Avatar
Check your EGR valve as it controls NO emissions.
Old Nov 1, 2006 | 10:02 PM
The low HC and low CO indicates it may be on the lean side. "Lean" causes NOx to increase.
Old Nov 3, 2006 | 10:42 AM
dst's Avatar
dst
Smile
Thanks for the info.
I'm going to look at my EGR valve and lines and also fill up with mid-grade octane this weekend.
Old Nov 5, 2006 | 09:48 PM
dst's Avatar
dst
Smile
Anyone think this could be due to low quality gas?
I made an EGR thread:
http://web.camaross.com/forums/showt...71#post4206871
Old Nov 5, 2006 | 11:02 PM
NOx is formed from high combustion chamber temperatures, and high O2 concentrations in the A/F mix (lean). Could be running lean, coolant temp could be too high, possibly the use of oxygenated fuel. Using low octane fuel may cause detonation, which may increase combustion chamber temps, but only if the knock retard system was not responding correctly.
Old Nov 10, 2006 | 11:12 PM
dst's Avatar
dst
I'm thinking it may be the EGR valve or the gas I was using.
The Mobil 1 station I get my gas from causes my dad's Ford to ping and it seems to make my motorcycle vibrate more at higher RPM. (SEEMS).
The plugs seem OK... The fuel system should be OK since I've been using Lucas every fill up for last 6 months.
Old Nov 10, 2006 | 11:20 PM
razor02097's Avatar
my 94 failed cause the ****er driving wouldn't shift into 3rd... I filed a complaint with management but they don't care.
Old Nov 11, 2006 | 08:18 PM
dst's Avatar
dst
I'm confident that my smog tech is competent.
Old Nov 14, 2006 | 11:16 AM
dst's Avatar
dst
Is there a more technical-based forum for Chevrolet vehicles?
Old Nov 16, 2006 | 12:09 AM
dst's Avatar
dst
I just passed and the tech did both the 15 and 25 MPH tests in first.
Dzmaro
Jun 19, 2015 11:38 AM
naaz90
Jul 27, 2002 08:22 AM
