Car's Hard To Start
Old Oct 30, 2006 | 09:37 AM
Tails's Avatar
Car's Hard To Start
Got a wierd issue. 2000 TA is hard to start pretty much anytime. After it starts it runs great but if I shut it off and try to start it again, nothing. I have to sit and crank it over quite a few times before it'll fire. I've got good fuel pressure at the rails, doesn't throw any codes, new fuel pump has been in for close to 6k miles. I've changed the plugs cause this is it's nice way of telling me it's time but it didn't work. I've checked all my plug wires with a multimeter and they are all fine. So I'm at a loss right now as to what is going on. I'm going to pull the fuel rail off tonight to see if I have a leaky injector but if anyone has any other ideas throw em out..
Oh the car is a H/C car with AFR205's, FAST90/90, 30lb injectors, racetronix fuelpump..
Tails
Old Oct 30, 2006 | 11:52 AM
SSpdDmon's Avatar
Does it start easier if you push down on the gas pedal while cranking? I'm thinking it might not be getting enough air...
Old Oct 30, 2006 | 01:45 PM
Tails's Avatar
Naw it's the same if I do that. Had another guy tell me it might be the ignition relay cause I don't get a code, security light, nothing. I'll try swapping it out when I get home...
Tails
Old Oct 30, 2006 | 11:10 PM
Tails's Avatar
Yep it was the relay. Came home and swapped it with the starter relay and it fired right up. Swapped em back and it fired breifly then died. So ran around to Checker and picked up another one. Woohoo..
Tails
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
